Air Conditioning Post issues with air conditioning here
Faulty A/C button
Old May 4, 2022
Docusn's Avatar
Docusn is an unknown quantity at this point
Faulty A/C button
I recently purchased a 2003 civic for 500 bucks because the transmission was supposedly bad. We put a new CAT converter and the trans and car run great. Only problem is the A/C button won’t engage or turn on the A/C. I had the A/C serviced and it is fine, just won’t turn on with the A/C button. What else can I do to fix the button for the A/C
Old May 4, 2022
BrotatoChip's Avatar
Super Moderator
Re: Faulty A/C button
Will it turn on if you bypass the relay?
Old May 4, 2022
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
How did they service the A/C if they couldn't turn it on?
Old May 4, 2022
There's a whole bunch of stuff involved in controlling the AC system, the pushbutton switch itself is not a likely cause of the problem.
Old May 7, 2022
Docusn's Avatar
My son had it serviced and it worked. I guess they bypassed the starter relay. The on off button won’t turn it on.
Old May 7, 2022
Docusn's Avatar
I think so. My son took it in and the mechanic serviced it, no leaks or problems other than the A/C button doesn’t turn on the A/C.
Old May 9, 2022
Super Moderator
If the system is low/empty, the A/C button won't turn on or engage the compressor clutch. The very first thing that should happen is the system pressure should be checked. If you force the compressor on when it's low/empty you will cause damage.
Old May 9, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Just in case this is remotely the issue but the A/C button light will not illuminate if the fan speed dial is in the off position.
JrCivicEX02Coup
Jan 6, 2011 01:30 PM
regor
Nov 3, 2008 11:31 PM
Keyees
Apr 3, 2007 10:41 PM
TeenHeartthrob
Sep 28, 2002 03:21 PM
