Air Conditioning Post issues with air conditioning here
Cant remove ac clutch plate
Old Jun 28, 2020
pippo's Avatar
pippo is an unknown quantity at this point
People,
2001 civic ex, trying to remove clutch plate so I can adjust the gap. I removed the 14mm nut. There is now a threaded stud exposed and no way to pull the plate off, as it is very tight around the spline and gentle prying with a screwdriver did not loosen in. I hate to pry harder as I am afraid of damaging/warping the thin clutch plate. How do they do it?
Thanks.
Old Jun 28, 2020
Colin42's Avatar
Re: Cant remove ac clutch plate
Buy a 2/3 jaw puller, there might even be a specific AC clutch puller
Old Jun 29, 2020
pippo's Avatar
Thanks, Colin. Got it out. Plate is severely worn inside surface where it meets the clutch , thats why it skips when engaged. Know where I can buy just a plate without the entire clutch kit?
Old Jun 29, 2020
BrotatoChip's Avatar
Super Moderator
Doesn't look like you can buy just the plate, no specific part number. You could probably go grab one from a junkyard but I would recommend just replacing the whole clutch.
Old Jun 29, 2020
pippo's Avatar
Thanks, Colin. Will do.
Old Jun 29, 2020
If the gap was just too wide from typical wear, causing slip and intermittent disengagement (and usually a visible wobble as you watch it spin)----- sometimes, depending on what's in there to work with, you can sometimes remove a shim to reduce the gap (at this point any bit helps, but if you get the gap too small it causes problems too)
If it works, it was a free fix and it buys you time and possibly a lot of miles
If it doesn't help.....well it was already broke before I got here lol
Old Jul 2, 2020
pippo's Avatar
Good to know, ezone. I thing new is the way to go since it is cheap, Will let you know what happens,,,,,,,,,,,,
Old Jul 2, 2020
pippo's Avatar
Wanting to install new clutch with plate. Can I just remove the retainer clip holding the clutch and pull with a puller or must I first loosen the belt? If I must loosen belt do I loosen the tensioner bolt which is somewhere near the alternator? Do I have to yank the power steering pump?
Thanks.
Old Jul 2, 2020
Colin42's Avatar
I would loosen the tensioner before pulling the clutch. It would be a good idea to replace all belts while you're in there. But if you don't want to do that I don't think you'll have to mess with the power steering. Might give you more room though
Old Jul 2, 2020
pippo's Avatar
OK, Ill try it Colin. belts were done just a year ago. I will try to access the tensioner from the wheel well area. There is 1-12mm bolt on the banana shaped "slide" and at the end of that there is a wing nut. Which to do first? Or just one? Or both? Confusing set up, ehh?
Old Jul 2, 2020
pippo's Avatar
OK, got the alternator loose, and belt off, now do you need a 3 jaw puller for the ac clutch? I have an AZ kit but doesnt have any 3 jaws in it.
Old Jul 2, 2020
Colin42's Avatar
2 jaw should be ok
Old Jul 3, 2020
pippo's Avatar
I got the new clutch on !! put it all together and wow, all works great! I skipped the replacement of the inner coil, as that would have been a pain and I know it was a gamble, but so glad it was only the worn out clutch/plate. Anyway, thanks to all especially Colin.
Old Jul 3, 2020
pippo's Avatar
I celebrated too early as I drove the car and engine kicks/lurches with ac on. the clutch seems to go on/off erratically, although now with the new clutch it does not squeal. I did not install the new coil that came with the kit. Yes, I know it could be that but any way to test the coil thats on there now? Could it be something else?
Thanks, people.
Old Jul 19, 2020
The compressor is supposed to cycle on and off so the evaporator core doesn't freeze up.
Is this the first time the AC has worked since you owned the car?
yourinmyw0rld
Transmission
Aug 21, 2019 04:45 PM
kkiley
Mar 30, 2017 06:43 PM
JJ291
Jan 23, 2016 11:28 AM
granny828
Jun 26, 2015 10:36 PM
cbeam2
Jun 10, 2010 10:16 AM
