Air Conditioning Post issues with air conditioning here
AC system won't engage
Old Jul 13, 2020
  #31
thebigbarn's Avatar
thebigbarn is an unknown quantity at this point
Re: AC system won't engage
Right! Thank goodness most of that was winter and the heater works great.
Old Sep 16, 2025
  #32
YellowGmc's Avatar
YellowGmc is an unknown quantity at this point
Originally Posted by thebigbarn
I was able to jump the blue/white pin to the red pin in the field coil connector and everything appears to be "working" - meaning, with the key in the ON position, the blower on, and pressing the AC button, I hear the click in the relay and the condenser fan turns on!!
The Compressor Thermal Protector Replacement diagram on page 21-51 does not show the supply line pipes but looking down into the engine compartment, it looks like this part could be replaced without having to evacuate the system and remove the lines (after removing the power steering pump and alternator). Do you have any tips about replacing it?
im having the same issues you were having. I have one wire a red/blue wire going to the thermal protector and the other 2 going to the pressure switch and I’m confused on how you jumped it and verified it was your thermal protector, thanks
Suraj Khellawan
Aug 29, 2017 08:50 PM
Packrat0113
Jul 23, 2017 09:36 PM
gulzarh
General 7th Gen
45
Jul 3, 2017 12:08 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
