Air Conditioning Post issues with air conditioning here
A/C issue need HELP
Old Jul 31, 2019
Ryenol's Avatar
Ryenol is an unknown quantity at this point
A/C issue need HELP
Just got a 2001 civic sedan. AC SYSTem will not take in any 134..
Old Aug 1, 2019
Colin42's Avatar
Re: A/C issue need HELP
did you check if there's any already in it? do you have a proper set of manifold gauges or the crappy single one that comes with the can?
Old Aug 1, 2019
BrotatoChip's Avatar
Super Moderator
If trying to fill an empty system did you pull a vacuum and check for leaks first?
Old Aug 1, 2019
Ryenol's Avatar
It would cool only going down the highway at first so I attempted to put more refrigerant in.(already made sure BOTH aux fans were on at idle). System would not take in any (the can did not get cold at all). Vent temp did not change. So I bled some off thinking maybe it was overcharged... I would guess not because then it would not get cool even on the highway..
I did some reading and it sounded like expansion valve may be bad. So I dismantled under glovebox and replaced expansion valve and flushed system out and no apparent crud came out. Then pulled a vacuum which it held. Again attempted to put in some 134 to no avail...
Old Aug 1, 2019
Super Moderator
Reading pressures on both sides with a proper gauge would help troubleshoot.
Old Aug 1, 2019
Ryenol's Avatar
I put a set of gauges on it but not sure if they are accurate.. low side was high and high side was around 100 maybe more, but not a lot...
Old Aug 1, 2019
Ryenol's Avatar
Going to use a set of gauges
from
a friend again to see if same readings but im
at work now
Old Aug 1, 2019
Super Moderator
Get readings while the A/C is on. After sitting for a while both sides will be about the same pressure, I believe around 100 PSI. Once the compressor kicks in the low side should drop and the high side will rise.
Old Aug 1, 2019
Ryenol's Avatar
Thank you. I did check while running the other day and the low side was high and they did NOT equal
out at all
minabear
Idle Issues
Jul 16, 2019 04:43 PM
huskerfoos
General 8th & 9th Gen
Aug 28, 2018 08:09 PM
AaronSorenson
Jul 7, 2015 09:40 PM
brett.guthrie
Apr 27, 2013 09:49 PM
dagua002
Jan 17, 2010 01:53 PM
