Air Conditioning Post issues with air conditioning here
2003 Civic A/C problem?
Old Mar 21, 2019
BiggaNinja's Avatar
BiggaNinja is an unknown quantity at this point
Hey all,
I checked the forums firstly, but couldn’t find aboyone with this exact problem.
So my 2003 civic does not blow cold air out the vent. Just outside temp air. To start, I checked the Freon with a pressure gauge, it was in the 50ish range and stayed in the green. I next checked the a/c compressor and could see the clutch spinning and it small pull on the engine when on and cut off and disengaged when cut off. I next checked the condenser fan and cuts on fine when a/c is cut to on, and off when turned off. Now I don’t know where to go from here before I turn this over to a mechanic, any help is greatly appreciated.
Old Mar 21, 2019
Re: 2003 Civic A/C problem?
huh, and did not see the air conditioning section of the site?
moved to right section... should help
Air Conditioning
23
Jun 9, 2023 06:27 AM
kroenen2
Jul 20, 2017 04:43 PM
jaysmachone
Jun 2, 2013 12:38 PM
max785
Aug 24, 2011 08:04 PM
trev98
May 29, 2010 11:24 PM
