Air Conditioning Post issues with air conditioning here
I fixed my a/c compressor... in winter
Old Nov 29, 2018
onetwoothreee's Avatar
onetwoothreee is an unknown quantity at this point
It works! And... it's 30 degrees outside. I couldn't be happier. Let me tell you what happened.
A while ago, I used one of those cans of refrigerant to "recharge" the system. Barely did anything, waste of money.
So, there's this guy on YouTube saying there's an easy way to fix your a/c compressor if the clutch isn't engaging (me). I don't even know how long it hasn't worked. You take the clutch plate off and remove a very small amount of metal, then put it back on. Here's a picture of what sits next to the compressor. In the second picture, you can see a very small washer. If you take too much metal off, replace it with a slightly thicker washer when reassembling and it will still work. Everything looks wet because I sprayed it. I used some 120 grit sandpaper to knock the rust off and it turned a lot more smoothly. The defrost (heat) turns on the compressor now! Technically the air should be drier, maybe fog up less? I don't know. Where's that video?
Old Nov 29, 2018
Re: I fixed my a/c compressor... in winter
How do you hold the clutch plate in place while you're loosening it? Duh! PS: removing too much metal locks them together (gets hot in a hurry). Go too big on the washer and the plate will sit too far away, meaning it won't engage again.
Old Nov 29, 2018
Your refrigerant can also be so low the compressor won't start. I recommend going to a shop to have a full evacuation and recharge done if you can get it going.
Old Nov 30, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Yes this repair does fix the A/C. Removing a metal shim around the compressor clutch shaft closes the air gap so that the magnetic plate engages the clutch again. Over time the air gap becomes to much for the clutch to engage. Dealer recommended to replace the A/C clutch $$$ but I took it to an A/C specialty shop and it was done in no time at $40. This was 5 years ago and still OK.
Old Nov 30, 2018
BrotatoChip's Avatar
Super Moderator
You can easily check the gap yourself to ensure it is within the service range.
Old Nov 30, 2018
The feeler method in the image is for new part setup (both surfaces are perfectly flat), but as shown it doesn't work good on an old clutch that has a lot of wear.
Pics of wear, probably 200k miles on this AC clutch set:
Old Dec 2, 2018
Yeah I suppose you could do that. I wasn't sure what function it served. I happened to have a similar size washer that I just stacked on top of the one already there and noticed that using a single larger washer didn't allow it to spin as freely. You can very clearly see where the washer is seated between the plate and the bearing. The orange part is some kind of rubber.
Old Dec 2, 2018
PS: I used the top part of a floor jack (mine comes off) to keep it from moving.
Old Dec 2, 2018
Old Dec 15, 2018
I found the actual part. This website has diagrams and labels for almost everything (not affiliated with site). https://www.hondapartsnow.com/
civicforumguy20
Jul 28, 2018 12:04 PM
G3rain1
Jul 17, 2016 07:33 AM
rcode
Mar 2, 2016 09:13 PM
Froudeg490
Mar 24, 2012 12:54 AM
tradosaurus
Apr 25, 2011 11:52 AM
