A/C Shuts Off, Gauges Drop, Sputters, Dies
I have a 2005 Honda Civic. It starts up, runs for about 30 seconds, then the A/C turns off, the dials/ gauges drop. It runs for another 20 seconds, sputters, then dies. It won't restart right afterwards. Need to let it sit before it starts again.
I changed the battery terminals, thinking it was a battery issue. Didn't work. Any ideas?
I have a video. I turned the car off before it sputtered and died. Otherwise it would have done that. Thanks.
Re: A/C Shuts Off, Gauges Drop, Sputters, Dies
Bad connections between battery posts and clamps, or between clamps and cables.
I had that happen once while driving, it was the alternator.
To test it:
-Place a multimeter (set to test dc voltage) across the battery before you start the car.
-it should read 12v or so ***if you have a full charge***
-start the car; the voltage should climb to 13.4-14v.
Either way, if your battery is charged or not, there should be a climb in voltage. If you see a drop when you start the car, the alternator is dead.
To test it:
steve6
Nov 22, 2015 08:18 PM
danfry21
Oct 31, 2015 02:26 PM
