Engine start problems Post issues with engine start here. Does not start, does not run, etc.
'04 Civic Crank, Intermittent no start
Old Apr 29, 2024
saynielsen3's Avatar
saynielsen3 is an unknown quantity at this point
I've had a problem with my 2004 Civic not starting occasionally (mostly between 5-10 min. / 1hr 30min.) after turning the engine off. I've spoken to 2 different mechanics, one said it was a problem with the crankshaft position sensor. The other one said that it was likely a problem somewhere within the fuel system because, 1. There are no codes, and 2. he sprayed starting fluid into the air intake which allowed the car to start, and he said that means it should be a fuel problem, and not an electrical problem.
The fuel pump was replaced a little under a year ago.
If anyone has any ideas as to what the specific problem could be, I would be very appreciative.
Old Apr 30, 2024
Colin42's Avatar
Re: '04 Civic Crank, Intermittent no start
Sounds like fuel is the right place to start.
If you can't troubleshoot, you're going to have to pay someone to do it.
Bigfella
Jul 2, 2023 08:49 AM
CraigDillon
Jun 30, 2017 09:14 AM
ndskimr
Dec 14, 2016 11:47 AM
HondaNewb
Nov 16, 2016 12:11 AM
fahadlovely
Oct 11, 2007 08:32 AM
