Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2002 honda civic cranks no start [solved]
Old Apr 14, 2024
earlyt766's Avatar
earlyt766 is an unknown quantity at this point
I have a 2002 honda civic ex 1.7 v tech will not start after rebuild. New cam sensors,crank sensor is in time and has spark. Fuel pump primes but is getting no fuel to the plugs. New o rings on injectors. Also when I turn on the key to try to start or just turn on the light on dash assembly stay on even if you remove the key. The only way to shut them off is to discconect battery.
Old Apr 15, 2024
BrotatoChip's Avatar
Super Moderator
re: 2002 honda civic cranks no start [solved]
Do you have engine grounds connected? Been a while since I messed with a D17 but there's one from water neck to radiator support, and another from water neck to battery negative I think. Maybe another from the engine harness to the engine.
Old Apr 15, 2024
earlyt766's Avatar
Yes all grounds are good. Checked this morning and getting injector pulse and getting spark. I'm going to install new plugs and coil boots in the next couple days.
Old Apr 15, 2024
Just a dummy check. Any codes being thrown?
Old Apr 17, 2024
earlyt766's Avatar
I found the problem of not starting. The cylinder walls were washed out from the gas being injected and no firing. I replaced cam and crank sensors.. Compression was low. I squirted WD40 in cylinders and put the plugs back in and it started right up after it burned the excess WD40.
greasemonkey30
Sep 1, 2021 10:51 PM
SergeB
ECU Fried
17
May 1, 2021 06:58 PM
mkjohnson831
15
Nov 11, 2016 01:48 PM
laxfan17
Jul 27, 2016 10:19 PM
mkjohnson831
22
Jun 12, 2016 07:46 AM
