Engine start problems Post issues with engine start here. Does not start, does not run, etc.
How do i put an engine back into time after it has jumped timing?
Old Sep 22, 2022
Jmarina914's Avatar
Jmarina914 is an unknown quantity at this point
Exclamation How do i put an engine back into time after it has jumped timing?
Have a 2001 LX. was working under the valve cover today to do a couple of things ( valve adjusment, tube seals, vc gasket, etc. ). as i was preparing to adjust the valves i noticed that when i had the cam gear at TDC, the crank pulley was not in time.The mark that is on the crank pulley is not lined up where its supposed to be. Led me to believe my car has jumped timing which i think was the reason a couple weeks ago my cars engine randomly died twice. So i wanted to know how would i go about putting the engine back into time? Remove belt, line up the crank pulley, line up cam gear, and put belt back on? I'd would really appreciate any tips/advice. Thanks Fellas.
Old Sep 22, 2022
Re: How do i put an engine back into time after it has jumped timing?
https://www.civicforums.com/forums/1...ne-timing.html
Important note: did you put the engine in the right position before checking?
crankshaft rotates twice as fast as the camshaft
Old Sep 22, 2022
Jmarina914's Avatar
Thanks for the reply! by right position do you mean having cylinder #1 at TDC? Or did you mean something else?
Old Sep 23, 2022
cylinder 1 can be in TDC, but camshaft can be in two different positions, depending on which cycle the cylinder is in
Old Sep 23, 2022
BrotatoChip's Avatar
Super Moderator
If the engine is out of time you will want to do a full timing belt job (timing belt, tensioner, likely a water pump). Reusing the same belt/tensioner is just asking for it to jump time again.
Old Sep 26, 2022
Jmarina914's Avatar
Gotcha! Thank you!!
POS90civic
Feb 18, 2014 10:23 PM
wastintime
Jan 1, 2014 09:46 PM
bikes_and_plane
Jul 15, 2013 05:00 PM
Thaik
Sep 20, 2011 07:36 PM
