Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Cranks no start
Old Oct 26, 2021
Frostysinco's Avatar
Frostysinco is an unknown quantity at this point
Cranks no start
It was starting up before I replaced the transmission fluid and now it won’t start. ( I replaced the fluid because it wasn’t picking up speed
update*
it just need more transmission oil now it runs
Old Oct 26, 2021
FRSam's Avatar
Click Here
Re: Cranks no start
Have you addressed P0118 yet?
Old Oct 26, 2021
Re: Cranks no start
I’m not sure I get a dtt code when I run the check engine code gadget
Old Oct 26, 2021
Re: Cranks no start
I’m getting check engine light on and clicking in the cluster. No code just dtt
update’ the car starts with the scanner on
Old Oct 27, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Cranks no start
Check for faulty PCM. Are the alternator bolts tight as these are the ground for the alt. Loose bolts cause a fried PCM.
Old Oct 28, 2021
thetut's Avatar
thetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of lightthetut is a glorious beacon of light
Re: Cranks no start
Check your grounds, particularly the one beside the thermostat housing.
corysam
Transmission
Jul 22, 2023 09:02 AM
David Fayers
Transmission
Dec 20, 2019 01:11 PM
EarleD
Jun 25, 2017 01:59 PM
palsana
31
Jul 15, 2012 05:34 PM
Silver2k1Dood
Aug 2, 2002 02:33 PM
