Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Code P0171 and P1361
Old May 8, 2020
Quiznos 713's Avatar
Quiznos 713 is an unknown quantity at this point
I own a 2002 Honda Civic the previous two owners neglected the car so I've been trying to fix it up I decided to switch the fuel filter because I was experiencing hesitation the car ran fie for an hour till I got on the highway way I wasn't accelerating as much as usual when I got home the car wouldn't start anymore and the check engine like came on with the codes P0171 and P1361 any ideas for what it could be?
Old Jul 20, 2020
sinkenken's Avatar
sinkenken is an unknown quantity at this point
Re: Code P0171 and P1361
I had a problem from brand new 7th Gen car with 1.7 motor.
After running for a while and stopping engine, say for gas it would crank but was hard to start.
Last year on really hot days the engine would just stop intermittently for no reason and after about 10 minutes I could start it normally again.
Eventually found the problem was the TDC Sensor failing with heat soak at garage or during really hot weather (>38deg C)
Old sensor had J5T23991 2509 PLC written on it.
I replaced it with 37840RJH006 Sensor from Honda which Supercedes J5T23991 2509 PLC
It was showing Fault Code P1361 when it was failed and hot.
Hope this helps.
ob1ob
Jun 29, 2018 06:48 AM
Hayden_Fourroux
Nov 16, 2014 09:32 AM
malcolm2
Jun 30, 2014 12:22 PM
rcclem
Jul 1, 2012 02:18 PM
streetglower
Jan 18, 2005 07:16 PM
