Engine start problems Post issues with engine start here. Does not start, does not run, etc.
01 civic no start when hot
Old Jan 26, 2020
2hi4u's Avatar
2hi4u is an unknown quantity at this point
01 civic no start when hot relay s been changed temp sensor changed cam sensor changed thermostat changed . Need help runs good till u shut off than no go till it cools down
Old Jan 26, 2020
2hi4u's Avatar
Re: 01 civic no start when hot
Any one know if it could be crank sensor
Old Jan 26, 2020
Slumpertcivic's Avatar
Free test is to simply unplug it and see if it starts / restarts hot.
To be clear, I would unplug the O2 sensor first and see if the car starts up when hot, if it doesn’t with the O2 sensor unplugged then I would try the crank sensor..
Old Jan 26, 2020
Wankenstein's Avatar
Parts you changed:
1) Fuel pump relay
2) ECT sensor
3) Cam Sensor
4) Thermostat
Remove and clean battery cable terminals and battery posts with a brass wire brush. Apply vaseline to the battery cable terminals and battery posts to prevent corrosion. Trickle charge the battery for 8 or more hours. Clean all chassis and engine grounds and ensure they are tight. While the battery is disconnected check the alternator connections for tightness and the alternator belts as well for the correct tension. Check starter cables for tightness and corrosion.
Old Jan 27, 2020
Colin42's Avatar
Did you use cheap aftermarket sensors because that's what they had at AutoZone?
Old Jan 27, 2020
2hi4u's Avatar
oem parts used . Still cant start when hot ill try o2 sensor tonight. Will the crank sensor fail when it gets hot
Old Jan 27, 2020
The crank and cam sensors use magnets and indeed they can “fail” when hot. You should be getting a MIL code though as the computer is pretty good at noticing errant data from those sensors.
Old Jan 27, 2020
2hi4u's Avatar
Ive herd of them failing as its running never after shut off and try again. Ill try both tonight
Old Jan 28, 2020
2hi4u's Avatar
Update....... civic finally started when hot. Seems to be crankshaft sensor. Thanks everybody
2hi4u
Jul 20, 2020 11:45 PM
PG103
Aug 27, 2018 01:39 PM
jonhh
Aug 31, 2011 12:28 AM
king.0c
Oct 27, 2009 10:05 AM
