Engine start problems Post issues with engine start here. Does not start, does not run, etc.
Engine won’t crank no fuel pump no starter no spark.
Old Jan 24, 2020
Clarkie2121's Avatar
Clarkie2121 is an unknown quantity at this point
Can’t seem to figure out the issue seems to be an issue with a sensor or something electrical car is an automatic and no transmission lights will power up on the dash can jump starter and get it to turn over but won’t fire
Old Jan 24, 2020
Colin42's Avatar
Re: Engine won’t crank no fuel pump no starter no spark.
Green key flashing in the dash? Checked fuses?
Old Jan 24, 2020
No green key on dash, checked most fuses that I thought would be it, any specific ones I should check
Old Jan 24, 2020
BrotatoChip's Avatar
Super Moderator
I would suggest getting a good battery before troubleshooting too much.
Old Jan 24, 2020
Battery is good. All new grounds been chasing this issue for a week now. Motor threw a rod so I put a new one in and this started happening, all my accessories are on this motor, trans starter alternator etc
Old Jan 24, 2020
Also makes some kind of hum or growl from under dash/ behind radio somewhwre
Old Jan 24, 2020
Colin42's Avatar
Do you know how to do a voltage drop test? Might have a voltage drop in the battery terminals, I had that happen with my gfs 99
Old Jan 24, 2020
I’ll try this but not sure it is it, tried multiple batteries
Old Jan 24, 2020
Colin42's Avatar
You need to check terminals and the wires, swapping multiple batteries isn't going to do anything
Old Jan 24, 2020
Put new terminals and grounds on the vehicle
Old Jan 25, 2020
Colin42's Avatar
And?
Old Jan 25, 2020
And?
Still nothing, I done all of this before I made the post
Old Jan 25, 2020
Colin42's Avatar
Well it's alot easier for us to help you if you explain all that in your original post.
How are the connections on the starter?
It grounds through the bellhousing and I've seen them get pretty corroded
Old Jan 25, 2020
All connections seem good able to Jump starter and get motor to turn seems like a relay, communication to ecu proble
Old Jan 25, 2020
Colin42's Avatar
If you know how to use a multimeter you can test the ignition switch
Old Jan 26, 2020
I’ll try ignition switch but would that cause the fuel pump to not come on and no spark? Also no transmission lights light up on the dash. Really think there’s some relay somewhere that I just can’t find. Any better way to contact you?
Old Jan 26, 2020
Colin42's Avatar
Well yeah that's the whole point of the ignition switch. Just keep posting on this thread that way any other members with ideas can weigh in
Old Jan 26, 2020
Civic 2004's Avatar
Civic 2004 is an unknown quantity at this point
If I read your post right. This happened after an engine swap. The most common thing I have seen is the ground at the t-stat housing.
Old Jan 27, 2020
Super Moderator
Has the car run since you put new terminals and grounds on? If not that's the first thing I'd check. Bad power or ground caused by dirt, oil, corrosion, bad crimp, or just loose.
squirrelsurf69
Nov 16, 2012 09:14 PM
kurobaxkaito
Nov 3, 2012 10:43 AM
ssshassan
Dec 24, 2011 06:50 PM
twistless
Jun 16, 2011 02:32 PM
4jacks
Dec 11, 2004 01:57 PM
