2001 EX - Cranks But Will Not Start - Stalled While Driving
Old Nov 2, 2012
kurobaxkaito's Avatar
kurobaxkaito is an unknown quantity at this point
I have a 2001 Honda Civic EX AT and while driving down street, the car suddenly lost power and died out. I rolled the car to the side of the street and called AAA.
The AAA driver said it is a starter issue but it was still cranking. Anyways, the AAA driver banged the starter while I tried to start and it wasn't successful. In the end, he broke the starter and I was forced to replace it.
The problem is still the same and here is what I have done so far.
- Changed the starter
- Changed to new battery
- Checked most fuses (not relays)
- Listened for fuel pump (it seems to make a buzzing sound which should be good)
- Green Immobilizer key flashes and goes away (should be normal)
- Checked for spark (It's existent)
I removed what seemed like a fuel line to see if there will be fuel coming out but when I had my friend start the car, no fuel came out. Yet, the fuel pump does seem to prime up when the car is put on ACC position.
I have read that it may be the main relay but I wasn't able to remove the main relay and I am unsure how to test them either but I believe it is functioning since the fuel pump get's power.
What are some suggestions in finding out the issue? I have had a head gasket changed out recently due to overheating. Aside from that, I just did wheel bearings, ball joint, brakes, rotors, all the basic stuff that shouldn't mess with the engine.
Any suggestion will help and I will try everything and report back. I've read similar issues and tried all that I can try except for the relays.
Old Nov 2, 2012
mikey1's Avatar
Re: 2001 EX - Cranks But Will Not Start - Stalled While Driving
sounds like your timing belt might have snapped,
when you crank the engine does it sound like it cranks faster or sounds different than it normally does?
remove your oil filler cap, use a flashlight to look in there closely, have somebody else crank the engine over (try to start the car) while you look in the hole,
is the cam turning while the engine is cranking? you should see some type of motion/activity when looking in the oil filler hole, if there is no activity (nothing moving) your timing belt has snapped, if that is the case you are looking at very big $$$$ to repair the damage,
on a side note, i literally smacked my forehead with the palm of my hand when i read the AAA guy smacked your starter, how could a starter motor cause your engine to stop running?
Old Nov 2, 2012
We have in fact checked to make sure that the timing belt spins when we replaced the starter motor. I have a strong feeling that it is fuel related but I am not too sure where to start.
Old Nov 2, 2012
If he was any smarter, he wouldn't be driving a tow truck.....right?
Old Nov 3, 2012
so mean, lol. Anyways, I figured it might be fuel pump or fuel filter is clogged so I guess I'll be checking to see if there's anyway I can test the fuel pump.
Old Nov 3, 2012
Test, don't guess.
Fuel pressure test.
No pressure does NOT mean the pump is bad.
True pump failures are extremely rare on Hondas. These are not GM products.
I can count on one hand all of the Honda fuel pumps I have replaced in the last 9 years that were true pump problems, and have several fingers left over.
If there was no fuel in the line then it wasn't a fuel line.
Only one of the many lines carries liquid gasoline.
You'll have to actually find the correct line in order to test pressure, and have the correct adapters to connect a gauge to it for testing.
You mean the ON (or RUN) position. Nothing engine related operated in the ACC position.
Problem:
So the starter and battery were perfectly good and cranking the engine, yet you
SMDH. Now you have some cheapo starter of questionable quality from the discount parts store....waiting to strand you.
(Unless the word "cranking" means something different to you than it does to me....)
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
McD
Apr 16, 2015 10:46 AM
smmahan
Apr 15, 2015 08:17 PM
