Civic starts but shuts down with the smell of gas
Re: Civic starts but shuts down with the smell of gas
Park the car with the wheel cranked all the way to the left.
Remove spark plugs, remove valve cover, remove upper timing cover. With some long extensions you can sneak through the wheelwell to get the crank pulley to rotate the engine around to #1 TDC. You can stick something long down in the cylinder to help. The crank pulley TDC mark will be lined up with the pointer. And then the cam pulley will have 2 little marks that should be in line with the head surface. If the timing has jumped the cam pulley wont be lined up
Well just an update. Got the timing belt replaced as well as the water pump, serpentine belt, and p/s belt. All went well now that all that has been replaced and car running well my check engine light came on and now throwing out a P0420 code. This is a new code as it never showed up before. Any info or help would be greatly appreciated.
Thanks much in advance.
Cat code, could be from all the starting attempts. Clear it, do a few good highway drives to get everything nice and hot and see if it comes back?
AutoZone A/F sensor probably is not oem Denso/NTK/NGK sensor. This car (ecu) is very particular about the correct factory oem make and model A/F sensor, and maybe the cause of the code?
Call the AutoZone you purchased it from and ask them to verify the manufacturer. AutoZone just rebrands a lot of their parts under the Duralast name so you have to try to get them to be specific (if possible) of who is the true Original Equipment Manufacturer (OEM).
For future reference it's best to buy from online oem dealers like HondaPartsNow, Majestic Honda, or local dealer parts department rather than from chain autoparts stores.
Didn't realize you had swapped out the a/f sensor. Yeah make sure it's Denso or ntk
Hello
thanks for the replies. Yes the A/F sensor I bought from Advance Auto was a Denso sensor. I work 35 miles from where I live and have cleared the code 2 times since and still comes back on.
Again thank you all for your help and replies. Greatly appreciated as always.
How quickly does it come back?
could just be coincidence that the cat is failed
You can try a bottle of catalyst cleaner, it may help. If not the cat is done anyways
Hello. Ok just an update and some stats if they matter.
I have added a bottle of catacleaner to the fuel per instructions (1/4 tank or minimum of 4 gallons, drive 10-15 miles under normal driving conditions then fill up tank). However after adding the cleaner I was in a lot of stop and go traffic that day. After filling the tank I reset the code. 22.9 miles later (next morning) light came on again, same code. Before the code would come on around 45-55 miles after resetting.
now I googled symptoms of bad converter and I have none of these symptoms listed below. Actually I have just the opposite as things seem better then before
symptoms:
also I saw another symptom of poor gas mileage. I averaged before between 34-40 mpg prior to all this mess per an app I have on phone. When I filled up yesterday I was at 37.4 mpg.
now I’m wondering if maybe me being in stop and go traffic before filling up if that may have had an impact of the cleaner not working properly and should I get another bottle and try again but in less traffic and at more normal driving conditions.
symptoms:
- Sluggish engine performance.
- Reduced acceleration.
- Dark exhaust smoke.
- The smell of sulfur or rotten eggs from the exhaust.
- Excessive heat under the vehicle.
I have had the P0420 fault on my Civic for roughly 6 years. It does not cause any of the symptoms you've listed above although it is possible. If you don't have emissions testing in your area and don't care if the check engine light is on all the time then don't worry about it. Otherwise you can try replacing the secondary o2 sensor with an OEM one first before replacing the cat.
If you're talking about P0135 fault that's a different story.
That's why I suggested driving on the highway.
and it will throw the code without any of those symptoms, the computer is very picky. Which is why cheap aftermarket converters don't last long in these cars before throwing the code again because the computer thinks it's "bad"
I may also too replace the downstream O2 sensor as well since I’m sure that’s probably original and I’ve already replaced the upstream
theRedhatch
Dec 27, 2019 04:04 PM
mndthegap1
Mar 7, 2005 10:46 PM
Dticalman01
Feb 17, 2004 05:19 PM
