Engine start problems Post issues with engine start here. Does not start, does not run, etc.
2002 Civic. Good Battery. No Crank.
Old Nov 14, 2018
merc1100sc's Avatar
merc1100sc is an unknown quantity at this point
Hello all. Newbie here. Trying to remotely help my mother-in-law diagnose her issue.
Vehicle is a 2002 Civic 2dr. Automatic.
When trying to start, the car shows symptoms of a weak/dead battery. Does not crank and clicks (have a video I will attempt to attach).
Anyhow, apparently she tried jump starting it with no change in the result.
My question is, is there some sort of security feature that would make the car click as if its trying to start but not crank? I would think a security system would cut all power to start. Assuming that the chip in the key is going bad.
Any recommendations appreciated.
Thanks
File Type: mov
Old Nov 14, 2018
Colin42's Avatar
Re: 2002 Civic. Good Battery. No Crank.
starter could be bad, could try giving it a whack if she's able to, it sits on top of the trans.
could also be a bad connection, either hot or ground
Old Nov 14, 2018
merc1100sc's Avatar
Thanks. Those suggestions make sense.
In your opinion would you rule out the key/keychip? Someone she knows that knows some about cars is suggesting to get a new key but they aren't cheap.
Thanks
Old Nov 14, 2018
Colin42's Avatar
the security system cuts fuel not the starter, so its not that
Old Nov 14, 2018
merc1100sc's Avatar
Thanks
Old Nov 15, 2018
could even be rust on the battery terminals
bluehawk91
Dec 29, 2018 04:25 PM
Wumbles
Apr 16, 2018 07:15 PM
wpendl1
May 1, 2017 04:14 PM
TheCrimsonKing
Apr 25, 2015 09:40 PM
dsj09b
Feb 7, 2014 03:45 PM
