Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
Honda Civic 2003 LX feels like something is holding it back
Old Sep 30, 2024
Sasan's Avatar
Sasan is an unknown quantity at this point
Hello everypne,
My 2003 Honda Civic 2003 feels like something is holding it and doesn't let it accelerate when poressing the accelerator but if you press hard for few seconds it suddenly releases (like a bubble bursting) and it moves so great that you can't believe. Unfortunately this happens all the time and if you turn on the fan or A/C (it happens all the time without fan and A/C as well). The kind of feeling I get is that it could be the gas bump is blocked and the blockage goes away after the initial acceleration.
This happens when you want to start from beginning or even when you need to accelerate suddenly to a higher speed to enter the highway and as like scenarios. I am not sure if my explanations are clear but I will greatly appreciate any assistance.
Old Oct 1, 2024
Re: Honda Civic 2003 LX feels like something is holding it back
is it auto? Is engine revving more without accelerating?
Old Oct 1, 2024
FRSam's Avatar
Click Here
It’s a slow car. You need to push it hard in order for it to do anything. Sounds like you’re just pushing it hard enough that it’ll downshift rather than accelerate in the gear it’s currently occupying. It doesn’t sound to me like anything’s wrong.
Old Oct 1, 2024
Sasan's Avatar
Thank you for your reply.
It actually doesn't downshift in those occasions I mentioned. These occasions are mostly when the car just wants to start moving not when you are already driving.
Old Oct 1, 2024
Sasan's Avatar
It is auto and engine revs mostly normal but sometimes yes, I feel it is revving more than the acceleration.
Old Oct 2, 2024
these generation cars auto trans are famous for starting slipping, until it does not transmit anymore...
there is no cure, only swapping in a 04-05 trans in it.
Old Oct 2, 2024
FRSam's Avatar
Click Here
I suppose you could be describing a slipping sensation - I just didn't interpret it that way. If that's the case, your transmission is beginning to fail, which should be shown by stored code P0730. If it's not showing a check engine light, it's either a stored code (meaning put a code reader to it regardless) or it's at the beginning stage of failure and may not be throwing a fault yet.
What's the mileage and when was the transmission fluid last changed? That's a quick indication of what's going on.
Old Oct 3, 2024
Sasan's Avatar
The mileage is at 154000km. The transmission fluid was changed less than 2 years ago.
If that is the case, how much $CDN should I be expecting for the repair?
Old Oct 3, 2024
when it starts slipping, only way to improve (for some time) is drain and fill new fluid as per honda instructions.
Eventually, it will die and you will need to swap in a 04-05 trans into it
Old Oct 3, 2024
Sasan's Avatar
How much are we talking about here for new transmission??
Old Oct 3, 2024
use car-part.com to look out for scrapyards around you.
prices differ from region.
Old Oct 4, 2024
Sasan's Avatar
Would they be reliable and last?
Old Oct 4, 2024
BrotatoChip's Avatar
Super Moderator
'04-'05 transmissions were much more reliable. Some junkyards will offer you a warranty. Usually only 1-3 months.
kingrat
Sep 20, 2013 09:58 PM
Matt Connolly
Aug 5, 2010 09:49 PM
J.murray
General 7th Gen
Apr 27, 2007 03:12 PM
DCivicEX
Mid Atlantic
Aug 8, 2003 01:09 PM
WannaBFast
Mid West
Jun 23, 2003 07:23 PM
