Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
Transmission? Or something else?
Old Feb 22, 2022
modrummer's Avatar
modrummer is an unknown quantity at this point
Ok so I have a 2001 honda civic automatic, starts and runs great, revs up fine, but when you put it in gear it doesn't move. If you put your foot to the floor and nearly redline it, it will creep forward a little, and then sometimes lurch forward and start moving.
Thoughts?
Old Feb 22, 2022
FRSam's Avatar
Click Here
Re: Transmission? Or something else?
First off, don’t do that.
Second, what engine codes are there?
Once you check codes, the next step would be to do a 3x drain and fill. What that means is you drain your transmission, refill it, take it for a short drive if it lets you, then repeat the process two more times.
In all likelihood, it sounds like you may need to replace or rebuild the transmission.
Old Feb 22, 2022
modrummer's Avatar
I'll check engine codes tonight.
For the 3x drain and refill, is there something cheaper than ATF-Z1 that I can use? Seeing as thats $10/quart with a 6 quart capacity, that's a $180 test...
Old Feb 22, 2022
FRSam's Avatar
Click Here
Does that mean your check engine light is on?
It won’t be that much. It doesn’t drain everything all at once. It should be under $100 all-in. Not sure if you can use other fluid or not.
Get codes checked and report back. Look specifically for P0730 aka dead transmission.
Old Feb 22, 2022
Colin42's Avatar
Check Valvoline and Total. I think they each have a compatible fluid.
Old Feb 22, 2022
modrummer's Avatar
Will do.
It had an emmissions related code previously so the CEL is on, but haven't checked to see if it has any new codes. I'll scan it hopefully tonight.
Hoping to find a cheaper fluid I can use since I'm just going to be flushing it back out.
Old Feb 22, 2022
FRSam's Avatar
Click Here
Not flushing, draining. You WILL destroy the transmission if you flush it.
Old Feb 22, 2022
modrummer's Avatar
Sorry poor terminology on my side. Thanks
Old Feb 22, 2022
CraigW's Avatar
Do you know the history of past ATF services ?
Old Feb 22, 2022
modrummer's Avatar
No idea. My guess is it's been a LONG time since the tranny fluid was changed.
Old Feb 23, 2022
BrotatoChip's Avatar
Super Moderator
FYI the service manual specs 2.9 quarts for a transmission fluid change (drain and fill). Nine quarts would cover your three drain and fills.
Old Feb 23, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Yikes. Might be too late to save this trans. Internal filter and screens may be contaminated with clutch debris causing lack of ATF flow and failure to shift. Drain and fill of Honda ATF recommended at least every 30K miles. Check Owner's Manual.
Old Feb 23, 2022
modrummer's Avatar
Good to know, thanks!
I didn't have time last night, but I'll break out my scanner tonight and see what codes I have.
Old Feb 28, 2022
modrummer's Avatar
Sorry for the super late response. Codes are p0740 and p0730. Do these traditionally mean the transmission is toast? Or there is still potential with a couple drain and fills?
Old Feb 28, 2022
Colin42's Avatar
P0730 is typically the "death code"
Louis wayne
Nov 15, 2016 03:46 PM
ray13
Transmission
Jan 19, 2016 06:07 PM
BBrosario
Sep 17, 2015 07:51 PM
juanluis
Jul 23, 2013 07:29 PM
MAXI
Mar 9, 2010 07:34 PM
