Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
2003 Honda Civic - Transmission pan
Old Jun 24, 2018
Professorjade's Avatar
Professorjade is an unknown quantity at this point
Hey all, I’m in need of a little help. My transmission recently went out and I need to remove my transmission pan. But I’m a bit nervous to actually go in and start working. I’d take it to a shop but I don’t really have the necessary funds to do that. I’d like some advice on how to remove the pan and also inspect the filter for the transmission. Since that’s most likely what needs to be replaced from what I have been told.
Thanks.
Old Jun 24, 2018
Re: 2003 Honda Civic - Transmission pan
You should look under there first. There is no pan that can be removed.
The filter plugs up because the trans needs a rebuild or replacement.
Old Jun 24, 2018
Slumpertcivic's Avatar
The filter is buried deep inside.
if your asking for help in taking off the pan, your in for a world of special tools, knowledge, parts, skills, and work location to do that level of work.
I suggest you research this a lot more, there is a awesome video of a master tech taking one apart.
MadJoe
General 7th Gen
Sep 29, 2018 08:01 AM
Civic15
Jul 25, 2018 06:50 PM
April15Hater
Jul 17, 2010 10:59 AM
SOHC
15
Aug 21, 2004 08:45 AM
REDchirp
Engine Swaps
26
Jul 17, 2004 03:51 PM
