Lower ball joint angle capacity
Old May 4, 2023
Noah Katz's Avatar
Noah Katz is an unknown quantity at this point
The Civic ball joint looks like a good candidate to use in the front suspension of the reverse trike I'm designing.
If Amazon's weights are anything to go by, they're as light as they get, and will be overkill strength-wise for a 1000 lb vehicle.
Can someone tell me how much angular motion they can accommodate? The rubber boot doesn't look to have any corrugations to speak of so I'm concerned that's because there's not much motion to deal with.
Also, does the ball joint need to be clocked a certain way to get its maximum travel? I watched a few youtubes of Civic BJ replacement and they just popped them in w/o any mention of that.
Old May 4, 2023
BrotatoChip's Avatar
Super Moderator
Re: Lower ball joint angle capacity
How much do you need? I'm not really sure what to guess. Maybe 15° in any direction from center.
Old May 4, 2023
Noah Katz's Avatar
15 deg would just about do it, thanks.
Old May 5, 2023
Super Moderator
FYI, that was a complete guess. I don't even have a ball joint to look at.
Old May 5, 2023
Noah Katz's Avatar
No worries; I found a thread where a guy measured suspension travel and got around 7", which is what I'm shooting for.
2005-civic-vp
Suspension
22
Nov 15, 2021 06:56 AM
dnmacdon
Suspension
Aug 19, 2016 05:46 PM
MrShorty
Suspension
Mar 6, 2015 12:39 PM
flirp
Nov 9, 2014 12:49 PM
Prodresurgence
Mar 14, 2010 01:03 AM
