Stuttering while accelerating
Old Oct 22, 2020
Vepy's Avatar
Noobie
Vepy is an unknown quantity at this point
When I accelerate the car tends to stutter, and the RPM's go up and down. I have to slowly speed up, to speed up. It may only do it when V-Tech kicks in, but I haven't done a ton of experimenting. I don't think it does it on certain RPM's, but I've gone slowly but at like 6k RPM, but it's done it if I put the pedal down too much/fast and had it stutter at 4k RPM.
The engine was rebuilt, but the trans has not. Could it possibly be the trans, or could it even be a sensor somewhere?
Fully stock engine, oils are kept up. Trans has a tiny bit more fluid than what's recommended on the dipstick indicator.
Old Oct 22, 2020
BrotatoChip's Avatar
Super Moderator
Re: Stuttering while accelerating
Low/inconsistent fuel pressure?
Old Oct 22, 2020
Vepy's Avatar
Noobie
Could that be from the fuel filter and or fuel injectors?
Old Oct 22, 2020
FRSam's Avatar
Click Here
That, or a weakening pump.
Old Oct 31, 2020
Vepy's Avatar
Noobie
Ok, so my father worked on it before I bought it. He said that the fuel pump was replaced, and the injectors looked fine. Is there a way to easily look at the pump or a way to see if the injectors really are ok?
Old Nov 3, 2020
Vepy's Avatar
Noobie
So the transmission has a little more than what the level indicator shows to fill it to, should I drain it a little? If so where would the drain plug be located, and do I torque it back to a certain torque spec?
Ol Mans 91 LX
Apr 10, 2018 08:14 AM
lgn98868
Transmission
15
Feb 13, 2018 08:27 PM
0396
Oct 31, 2013 09:50 PM
Dmans99
Mar 30, 2013 09:39 AM
HCMCVTEC
May 21, 2012 11:00 PM
