Car won’t start
Old Apr 16, 2019
Chris Gaspar's Avatar
Chris Gaspar is an unknown quantity at this point
Car won’t start
Hey guys so I got a 98 civic ex coupe manual and for some reason the other day when i used my key to unlock my door my alarm started going off. I went to put my key in the ignition and start my car to turn off the alarm but my car won’t start. Not sure what to do. Any ideas? Thanks in advance
Old Apr 16, 2019
Colin42's Avatar
Re: Car won’t start
"won't start" isn't exactly helpful
cranks? doesn't crank? got spark?
can you bump start it?
Old Apr 16, 2019
Re: Car won’t start
Doesn’t make any noise like there’s a kill switch or something. When I open my door my car alarm dings and lights on odometer light up. When I put the key in and turn it it stops but the car won’t start or anything. No cranks, stutter nothing
Old Apr 16, 2019
Colin42's Avatar
Re: Car won’t start
ok, does your clutch switch still work?
again: can you bump start it?
Old Apr 16, 2019
Re: Car won’t start
Yes I can still push in my clutch. And I haven’t tried since I live on a hill and didn’t want to have to push it back up if it didn’t work. And you think a bump start would work even though my alarm still goes off and when I turn the key in the ignition nothing happens?
Old Apr 16, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Car won’t start
So wait, the dash lights up with no key in the ignition, just the door opening?
Any recent auto services or modifications?
Is there an aftermarket anti theift?
The bump start would narrow the issues down to a starter problem. So you would now that the ecu, injectors, sensors, fuses and wiring are working; other than what ever is causing the starter problem (including starter failure itself)
Old Apr 16, 2019
Re: Car won’t start
Correct. My alarm originally started going off a couple days ago but whenever I have my doors closed and leave it alone it stops. But soon as I open my door it starts up again. The lights will start flashing and the horn will start going and you’ll hear beeping.
And as far as aftermarket stuff not to sure about much just bought the car. It does have a after market stereo though I believe. So I’m thinking when they put the stereo they put in the alarm and anti theft.
93DxCivichatch
Apr 22, 2018 02:58 PM
DieselDrummer
Mar 2, 2017 07:55 PM
rujoesmith
Oct 25, 2014 09:05 PM
UnOrthodox9546
Jan 18, 2004 01:49 AM
WhiteRabbit
Oct 12, 2002 07:52 PM
