2000 Civic Ek Choking Problems
Old Apr 13, 2011
JapSir's Avatar
Nothing Sounds As Good As VTEC
JapSir is an unknown quantity at this point
Exclamation 2000 Civic Ek Choking Problems
I Have recently changed from the EG model over to the EK, And Everythin was great untill this
Car seems to chug when taking off and seems to be choking when driving and no amount of force through the exhaust seems to be clearing a blockage off any sort if it was even a blockage
I initially thought tht there was mabey a break in the exhaust further inspection showed there was a bracket broken off at the end of the down pipe which connects to the cat,new bracket got welded and everything put back together but the problem still persists !
The engine management light was on and still is on and the codes showed there was misfire in all 4 cylinders therefor all sparkplugs were replaced and yet again the problem is still there! I'm running out of ideas guys and ready to give in as this has been going on for months
Any Help Wld Be Much Appriciated Cheers
Old Apr 13, 2011
JapSir's Avatar
Re: 2000 Civic Ek Choking Problems
I've also replaced air filter ! Forgot to add tht
rcolosi
Apr 29, 2015 07:48 PM
shawe90
Apr 14, 2015 07:10 PM
tattedlariat
Apr 12, 2015 07:55 PM
dubbc
Nov 7, 2001 02:24 PM
silvervtec01
Nov 4, 2001 06:56 PM
