Electrical Post your Electrical issues here!
Gauges go wild when I use my turn signals
Old Aug 23, 2023
Greenrabbit's Avatar
Greenrabbit is an unknown quantity at this point
My gauges seem to work fine unless I use my turn signals or hazard lights, when I do the temp gauge jumps to hit, speedometer down to zero and my fuel gauge jumps to full. At the same time this happened my dash lights also went out. Any ideas? 99 civic dx
Old Aug 23, 2023
Colin42's Avatar
Re: Gauges go wild when I use my turn signals
Short somewhere in the dash. You're going to have to pull stuff apart and look
Old Aug 23, 2023
What does a short look like? How do I tell one when I find it and what do I do to fix it?
Old Aug 23, 2023
David13's Avatar
David13 is an unknown quantity at this point
You have a gremlin in there. An electrical anomaly. It will look like a loose connection or frayed wire. If you touch a wire and it falls off, bingo.
There might also be connectors that are not completely tight and connecting.
I had a Ford Tempo many years ago (it was given to me, guess why) and the turn signal would move the steering column and short out the ignition and shut the engine off. I don't recall what or how I fixed it with, maybe duck tape. I believe that was the last Ford I had. I hope.
dc
Old Aug 23, 2023
Colin42's Avatar
https://googlethatforyou.com?q=what%...look%20like%3F
R3DL1N3
May 3, 2004 03:00 PM
AirForce
Mar 24, 2003 12:18 PM
ImportRacer2123
Mar 14, 2003 05:04 PM
netcbc
Jan 16, 2003 02:12 PM
badcivic2002
Sep 15, 2002 04:33 PM
