Electronics Post your questions about Electronics problems here!
1998 Dx temp gauge wondering.
Old Oct 11, 2021
BackFireRabbit's Avatar
BackFireRabbit is an unknown quantity at this point
Exclamation 1998 Dx temp gauge wondering.
I have a 1998 civic DX. about a month ago the temp sensor for the gauge failed. I was dew for some maintenance so i did the T-belt, water pump. thermostat, sensor, oil change, trans flush and cooling system flush.
Now the temp gauge raises to normal vary quickly after starting cold and after warming up it will wonder from normal up to just below the red. I can plug in my OBD2 scanner and everything is work normal. Warms up alike normal Fan kicks on at 206 and off at 196. No loss of power, runs grate and same MPG as before all this happening. I have tried 3 different temp sensors and 3 thermostats thinking it was maybe a bad part but keeps doing the same thing. The only thing i can think is when the OEM sensor failed it damaged the gauge.
The car is 99% stock. The only non factory parts are the 3 row rad, silicone hoses kit and a JDM gauge cluster.
I should mention that when the sensor it temp gauge was pinned to hot as soon as the key was turned on.
Rushfan1
May 6, 2015 01:20 PM
rhvic
Nov 15, 2014 07:19 PM
stewartfan
Mar 22, 2012 10:57 AM
bvshearz
Dec 13, 2011 05:09 PM
RSDCivic
Aug 16, 2003 12:17 AM
