Electronics Post your questions about Electronics problems here!
new temp gauge reading about 90%
Old Dec 14, 2019
tim.ocallag's Avatar
tim.ocallag is an unknown quantity at this point
I had an issue with the fuel gauge so I ordered a new 78130-S00-A61 fuel gauge/temp gauge assembly. The fuel gauge now works but the temp gauge reads at about 90% (not red but not far away).
I put the other one back in with the bad fuel gauge and the reading is what I expect about 1/3 the way. I inspected the components on both temp gauges and they are the same value. The temp gauge starts at the bottom but hits steady state at the 90%.
All I can think of is that the gauge is bad ? Any ideas ???
old temp gauge
new temp gauge
side by side
Old Dec 14, 2019
GolNat's Avatar
Prelude Owner
Re: new temp gauge reading about 90%
Looks bad to me too. Is there a way to adjust the armature?
Old Dec 15, 2019
Colin42's Avatar
Is it from Honda? Or eBay?
Old Dec 15, 2019
the unit was bought off Amazon and its a genuine Honda part. I cannot adjust the armature. On the original fuel gauge I wanted to take the gauge off but when I pulled up on the needle it snapped off ..meaning it was not press fit on but glued. If I could transfer the old temp gauge to the new assembly I would but Im pretty sure if I was to pull up it would also snap.
Old Dec 15, 2019
Colin42's Avatar
Might come off with some heat
Old Dec 15, 2019
I've requested a replacement....if the replacement is the same...I will be very confused : )
Old Jan 2, 2020
Well a people indicated, the new one I had received was bad...i got it replaced and both the fuel and temp are working great. In the process, I snapped the needle on the speedometer (&^*(^&) but thanks to a hot glue gun I repaired it ! One other thing I found is that I could not read the gauges well at night... Turns out there are 2 bulbs on top that point down. I was able to buy a pack of 10 (#74 bulbs) at O'Reilly's for $8 and voila everything works perfect.
Thanks for all the advice.
replaced fuel/temp gauge
Old Jan 3, 2020
Colin42's Avatar
Glad you got it sorted
jrags
Apr 29, 2012 09:06 AM
stewartfan
Mar 22, 2012 10:57 AM
ill02civic
Jan 28, 2006 03:34 PM
MegaHurtz
Apr 18, 2005 01:54 AM
APS
Jan 17, 2003 11:17 PM
