4 Gauge to 0 Gauge input (output)
Hey, I'm in the process of upgrading my big 3. But I've ran into a considerably small problem.
I have this
https://i.imgur.com/D5uFx.jpg
on my positive battery terminal. It has an output for 4 gauge, 0 gauge and (2) for 8 gauge.
Problem is I'm using the 4 gauge for one amp and the new cable I have for the big 3 (positive to alternator) is also a 4 gauge. But there is only one 4 gauge output. I've heard of wire reducers (0 gauge to 4 gauge) but how would I go about securely fitting the 4 gauge wire in the 0 gauge output?
In short: Do they make anything for a 4 gauge cable to fit into a 0 gauge socket?
I have this
Re: 4 Gauge to 0 Gauge input (output)
just cut a bit more of the sleave from ur 4awg wire and fold it in half. stick it in and you'll get a nice tight fit.
have you tried to put the 4ga into the 1/0 spot? the clamps I've used in the past would still tighten down enough to clamp a 4ga in the 1/0 spot. otherwise, do what sleepy said.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
260000milesgoal
Sep 25, 2015 07:41 PM
