General Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
no speedometer :(
Old Apr 19, 2020
99ek's Avatar
99ek is an unknown quantity at this point
no speedometer :(
Hey guys I've got a b16a2 swapped and manual converter 99 ek civic running an obd1 conversion and since the swap it's got no speedometer
.I've replaced the sensor, and just tested the wiring at the sensor and I've got continuity between the ground and negative battery terminal, continuity between the signal wire and pin #18 on plug number c at the ecu, and accessory power to the power wire at the sensor.
I did the p06 to p28 ecu conversion myself and I'm curious if there's something in there that could be interfering? The cluster worked before the swap as well but i guess that's the only other thing to replace?
Anyone have any ideas?
Lars Durinck
Apr 19, 2020 10:22 AM
CMDR Karos
Electrical
Apr 27, 2019 08:13 PM
elit3x
Jan 30, 2017 12:06 PM
SWilsonLX
Mar 27, 2015 02:17 PM
Running Riot
Buy, Sell, & Trade - Archive
Feb 20, 2009 11:02 AM
