I can't open the hood on a Honda Civic 2005 LX
The button I normally have to pull to hear the click before opening the hood broke a couple of days ago. I didn't hear the click I normally hear (when the hood lifts up a little) so hood is still closed. I tried to use a wrench to pull that wire that is normally attached to the button that broke but nothing happens. I also tried to push the lever above the Honda sign with a flat level screwdriver towards my right but it also didn't help. Is there any way of opening the hood without the help of a mechanic?
Re: I can't open the hood on a Honda Civic 2005 LX
You need to get behind the grille and pull on the cable with some vice grips, or push the lever the cable is attached to with like a screwdriver. You may have to damage the grille to get in there, once you do have it open I would replace the latch and cable. You can try lubricating the hell out of it but it may be too far gone. There may be a video on YouTube showing you how to get the hood up.
EuroEMII
Aug 10, 2006 06:41 PM
