Headlight bulb
Old May 31, 2011
AG05's Avatar
AG05 is an unknown quantity at this point
Headlight bulb
Just venting....
Why does Honda's (or imports) makes it so hard to replace parts on these cars?!?! All I'm trying to do is replace the headlight bulb(s)...
Old May 31, 2011
Re: Headlight bulb
on a 7thgen? easiest lights ive ever had to replace. the PS reservoir pulls up on the driver side for tons of room, and the passenger side also has plenty of space behind the battery. shouldnt take more than a minute per side.
Old May 31, 2011
MindBomber's Avatar
Live for the Twisties
Re: Headlight bulb
I find it super easy too, even the signal marker bulbs aren't that difficult..
Old May 31, 2011
Re: Headlight bulb
heh unless you have tyc projectors, then the bumper has to come off for the park light lol. the hid is easier to change than the hi beam and park light.
Old May 31, 2011
Re: Headlight bulb
You can get at the parking lights from behind the fender splash guard.. Thats actually what it tells you in the owner's manual.
Old May 31, 2011
sl33pyriceboi's Avatar
Re: Headlight bulb
yea i never had a problem replacing mine or my friend's 03 civic.
do you have fat or gigantic hands? that might impede the process and make it harder
Old May 31, 2011
AG05's Avatar
Re: Headlight bulb
I was able to replace both headlight bulbs. I guess it was sticking since the headlights has never been replaced, but its done...
Old Feb 4, 2015
h4ldol's Avatar
h4ldol is an unknown quantity at this point
Re: Headlight bulb
Sorry to resurrect an old thread, but how do you pull up the "PS reservoir"? Actually, I don't even know what part that is but I'm assuming it's the part that's directly behind the driver side headlight that makes it so difficult otherwise to access the bulb? And you just "pull it up"? It would be great to get clarification on this since I really dread changing headlight bulbs because of the lack of space behind the driver's side headlight.
Old Feb 4, 2015
CraigW's Avatar
Re: Headlight bulb
Look real close, it likely lifts up out of a bracket.
Old Feb 4, 2015
h4ldol's Avatar
Re: Headlight bulb
Thanks, I'll take a look at it when I get home. If it's that easy, it'll be great because I like to use those xenon halogens that don't last very long.
Old Feb 10, 2015
section213's Avatar
section213 is an unknown quantity at this point
Re: Headlight bulb
Hi! What a coincidence this thread was bumped previously this week.
I am 'attempting' to change the driver's side regular headlight bulb on my Honda Civic 2004.
I have a found a very brief youtube video but I simply can not see how the bulb holder is being turned out of the socket. This bulb holder has to be turned and pulled out before removing/changing the bulb.
Is this clockwise or counter-clockwise from the drivers vantage point? I have tried both ways but don't want to exert pressure to break anything.
Is there a better instructional video / any other help? Thanks!
Old Feb 10, 2015
CraigW's Avatar
Re: Headlight bulb
Counterclockwise to release from drivers vantage.
Old Feb 10, 2015
Re: Headlight bulb
Unplug the connector before trying to rotate the bulb.
Old Feb 11, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
Re: Headlight bulb
Style..blame it on women engineers? Ha if it makes you fill better. Let Ezone do it for you. I have a 46 Chevy Truck that has silly dogbone fasteners all over it to keep owners from working on it. Says in the manual for the owner to take in in for all service. Truly Honda do engineer disassemble into their cars. Look at the right upper engine mount. Look a those bends in the ABS lines near it. Those are bent that way to enable you to get the wrench on the bolts and wiggle that huge mount out of there. Does help to do it on a regular basics. Most people take the upper mount off the body first. But it will come out if turned and rotated correct way.
Old Feb 11, 2015
greenbackz's Avatar
greenbackz is an unknown quantity at this point
Re: Headlight bulb
it is now super easy that i've done it a few times... i remember the first time took me forever for some reason. you're right tho just move the power steering reservoir and its super easy.. i usually remove my battery on the passenger side or i don't got enough room. there's vids on youtube for both the headlights and parking lights / turn signals.
don't remove your bumper.. that's just pointless unless your replacing the entire headlight assembly
Old Sep 13, 2019
0Civic's Avatar
0Civic is an unknown quantity at this point
Re: Headlight bulb
Well I made the headlights upgrade easily for my Civic. They look cooler than the old yellow halogen headlamps
gamerzfuse
Lighting
Dec 17, 2012 09:17 AM
torrens21
Jul 29, 2009 10:41 PM
civic $i 2006
Mar 18, 2009 11:44 PM
ctopher
Sep 2, 2007 06:39 PM
hologram
Mar 11, 2002 10:25 AM
