Mirror
Old Apr 24, 2007
BigRedEXcoupe's Avatar
BigRedEXcoupe is an unknown quantity at this point
Mirror
So I was recently in an accident, and my coupe lost her passenger side mirror. I recovered everything, but there is no salvaging it. The only part left connected to the car is a black plastic arm, with a socket at the end, that I assume was where the electric mirror pivoted, and several wires. I am looking to replace the whole assembly, and am wondering what I need to order.
Any help would be greatly appreciated
Old Apr 28, 2007
TRIZ's Avatar
Re: Mirror
Pretty much just the whole passanger mirror. If you pop off the sail pannel (panel directly where your mirror connects to your car- small triangle). You'll see the connector, and the bolts holding on to whats left. Unbolt the old piece after disconnecting the connector- twist/squeeze or whatever it is, and bolt on the new part, reconnect, and snap panel back on. You can get the replacement parts that you need though honda and build it back up yourself.
If your actual housing is cracked, you cant replace just that, you'll have to buy the whole assembly, which will run you 150 from your dealer, or 100 before shipping if you buy it online from majestic. If you want just the actuator, it'll cost you 33 from honda or 23 before shipping from majestic
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
carid
Sep 28, 2015 10:13 AM
MichaelLW
Sep 14, 2015 07:15 AM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
