General Post issues, questions that are not in the other sub-forums
2003 civic coupe vibration when a/c on..and in reverse
Old Jul 16, 2023
jhudson7583's Avatar
jhudson7583 is an unknown quantity at this point
hello all,
recently got a 2003 civic coupe, 106k miles, in pretty decent shape. had the car about 3 weeks now.
there is vibration noted in steering wheel when a/c is on, and when i put car in reverse. no cel light or code.
took it to my local mechanic, thinking the engine mounts needed replacing. he told me that engine mounts look good.
not sure where to look next? vaccum leak? spark plugs? MAP sensor?
transmission shifts fine with no issues. according to the carfax, the a/c compressor was replaced in 2017.
thoughts anyone?
Old Jul 17, 2023
Colin42's Avatar
Re: 2003 civic coupe vibration when a/c on..and in reverse
Ac puts a pretty decent load on the engine
Old Jul 17, 2023
BrotatoChip's Avatar
Super Moderator
What is the engine speed at when this happens? Lower than it should?
Old Jul 17, 2023
idle stays the same around 800-1000RPM. i realize the ac gives additional strain on engine. its not a terrible vibration, but its noticeable. no screeching or weird sounds from the compressor. idle stays pretty smooth.. im going to change out the plugs anyway and see if that makes any difference. not getting any codes or CEL light.
Old Jul 18, 2023
very good point, my other vehicles in the past (corolla/nissan rogue and ford taurus) never had vibration like this though. ive been doing alot of reading on civics and apparently from what im reading.. vibration issues are common with these vehicles, last night (july 17th) i changed out spark plug. seems to have helped alot with the ac vibration.. however im still getting the vibration when i put in reverse.
even though mechainc says it's ok, im still leaning torwards the transmission mount.
have appointment next week for 2nd opinion on the vibration in reverse. it's really a great running car, and im averaging 31 mpg.
DesertCivic
Engine DIY
Mar 14, 2022 08:31 PM
helpmefixpls
Oct 7, 2021 07:37 AM
jdawgzcivic
17
Feb 1, 2020 04:16 PM
tparrott00
Dec 23, 2014 08:15 PM
AzNxTigers
Lighting
Aug 13, 2004 11:39 AM
