General Post issues, questions that are not in the other sub-forums
Front jacking point question
Old Apr 4, 2021
Bobfrazier5526's Avatar
Bobfrazier5526 is an unknown quantity at this point
So I’m pretty new to jacking up my car as I’ve only really used lifts before. I need to jack up both of the front wheel to do some suspension work. I’m seeing mixed results on where to hack the car up. Can I use this point to jack up the car?
thanks
Old Apr 4, 2021
Re: Front jacking point question
I've used that spot before on my 2002 with zero issue.
Old Apr 4, 2021
okay great
Old Apr 4, 2021
https://www.civicforums.com/forums/3...ml#post4596449
Dude asking about the very same point
fwiw, I've also used the front tow hook as a jack point without issue. On the rear, I've used both rear sub frame and rear tow hook
Old Apr 4, 2021
Colin42's Avatar
Yeah that spot is fine
Old Apr 4, 2021
you see the big arrow in the plastic cover?
that indicate jack point
Old Apr 4, 2021
yeah I figured that was what it was for. Just wanted to get a second opinion. Thanks
Old Dec 27, 2021
7thgenlegend's Avatar
7thgenlegend is an unknown quantity at this point
I was curious about this too. Owner manual and service manuals just talk about jacking up the sides which makes it complicated or impossible to jack up both front and back to do a tire rotation without a lift.
If anything, just unjack slowly to reduce the shock on the control arm bushing when the wheels contact the ground if you have old bushings. As for engine mounts or any other subframe impact when lowering the off the jack I'm not sure, if anyone cares to provide input on the matter
TRIZ
Dec 16, 2008 07:32 AM
beadebaserr
Jan 24, 2007 07:45 PM
fuledya
Oct 18, 2005 05:04 AM
drew22mader
Jun 12, 2005 08:04 AM
zzjkimzz
Apr 22, 2003 10:03 PM
