Rear Disc Brakes and 4 to 5 lug Swap Post information on Converting rear brakes to disc and 4 to 5 lug here
5 lug and brake swap information em2, es1 01-05
Old Oct 18, 2009
NorCalEM2's Avatar
NorCalEM2 is an unknown quantity at this point
5 Lug and Brake Swap Information EM2, ES1 01-05
This lug swap and brake conversion is for people still have D17 motor.
But if you want to put in a K series motor this works as well.
Parts:
-RSX Base knuckles, front
-RSX Type S Knuckes, front (use this only if you have a K swap)
-RSX Base or Type S / SI hatchback 04-05 “EP3” knuckles, rear
-RSX Base or Type S / SI hatchback 04-05 “EP3” Brake Caliper Rear
-RSX Base or Type S / SI hatchback 04-05 “EP3” E-Brake Cable
-RSX Base or Type S Brake Lines for each Brake Caliper (by new lines)
-RSX Base or Type S Brake Caliper (check seals)
-RSX Type S Front Brake Caliper brackets.
-"I also would suggest to swap out your brake booster for RSX Type S, brake portioning valve, and Brake Master Cylinder. This is also going to require a little rewiring of your brake lines to the master cylinder."
-By new Brake pads and rotors. (You can buy brand new OEM Brakes from ACURA which will cost you the most money, or go after market which are better for harsh driving I went with EBC pad and rotors).
EBC Model numbers:
Brake Pad Part Numbers: RSX Type S
Part # Description
DP41193R EBC High Friction Upgrade And Race; Disc Pads; Rear;
DP41254R EBC High Friction Upgrade And Race; Disc Pads; Front;
DP31193C EBC Redstuff Low Dust Superstreet; Disc Pads; Rear;
DP31254C EBC Redstuff Low Dust Superstreet; Disc Pads; Front;
UD537 EBC Ultimax Pad Set; Disc Pads; Rear;
UD829 EBC Ultimax Pad Set; Disc Pads; Front;
Brake Rotor Part Numbers: RSX Type S
Part # Description
USR7127 USR EBC Sport Rotor Kit; Front; 11.8 in. Dia.; Set of Two;
USR7128 USR EBC Sport Rotor Kit; Rear; 10.2 in. Dia.; Set of Two;
-5 lug wheels 5X114.3 pattern. Stock offset of our cars are +45mm Rims must bet at least 16” and larger to fit around the RSX Type S calipers.
FAQ:
Can I use parts from new SI Coupe or Sedan 2006-2010?
-New SI coupe and sedan 06+ parts do not bolt up with out modifying your car a lot. I would not suggest buying any of these parts. Except for the rims will work.
If you have an 01-02 you must change out your lower control arms!
-rsx front lower control arms(stocks can be modified to work by using tapered washers and taking up the slack)
if you have an 03-05 you dont need to modify the front struts
if you have an 01-02 you can either get the later style struts and knuckle bolts, or you can drill out the strut holes and use larger bolts
ABS System?
-If you have ABS I would suggest taking it out. It is a headache to make it work. If you want to keep ABS you are going to need the ABS system from RSX Type S with all the sensor and cables.
Why does the 01-05 Civic w/d17 need the RSX Base Front Knuckles?
-Well the RSX type s front knuckles/hubs, and cv joints do NOT spline to the civic axles, but the civic axles do spline into the base RSX Base Knuckles/hubs. If you want to use RSX Type S brake calipers and rotors you must gab the RSX Type S brake caliper brackets off the RSX type S knuckles. (Note: if you are going to use RSX Type S Brakes you must use 16” rim or larger)
AFTER YOU DO THIS LUG SWAP AND BRAKE CONVERSION TAKE IT TO A SHOP AND GET YOUR CAR ALIGMENT!
FIRESTONE TIRE SHOPS HAVE LIFETIME ALIGMENT AS LONG AS YOU OWN THE CAR. IT IS WORTH PAYING FOR THE LIFETIME ALIGMENT!
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
[attach][/attach]
POSTED ALSO ON socalcivic.com, honda-tech.com, norcaltuners.com, 7thgenhonda.com
Old Mar 24, 2012
shizzy's Avatar
shizzy is an unknown quantity at this point
Re: 5 lug and brake swap information em2, es1 01-05
i have 4 rims but one of them is for 5 lugs is it possible just to change one, cant you just get an adapter?
Old Mar 24, 2012
sl33pyriceboi's Avatar
no....
Old Sep 24, 2012
v2famous's Avatar
v2famous is an unknown quantity at this point
I really like those Honda rims....where do you go to find Honda rims like that?
Old Sep 24, 2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
Those are Acura RSX rims with Honda center caps
Old Oct 30, 2012
CGaud's Avatar
CGaud is an unknown quantity at this point
I've found several different answers regarding the ABS system. Some say I can use my stock civic abs sensor and others say I have to change it out. Anyone have a parts list of items needed to keep abs functioning?
Also... I'm assuming that because I have an 03 Coupe don't need to modify my front lcas to fit the longer screw on the rsx balljoint?
Old Jan 2, 2013
ktuna's Avatar
ktuna is an unknown quantity at this point
I have an 05 Civic EX SE with the Eibach Pro-Plus Suspension Kit along with Skunk2 Lower Rear Control Arms and Cambers. I'm interested in doing this swap, but am wondering if my after market parts will still fit or not. Thanks for any input! ( :
Old Jan 3, 2013
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
^ all your aftermarket parts will still fit
Old Jan 3, 2013
ktuna's Avatar
Thumbs up Re: 5 lug and brake swap information em2, es1 01-05
All wheel disk and 5 lug here I come! LoL Thanks!
Old Jan 3, 2013
Muirsy's Avatar
^ if you need any help let me know
Old Apr 8, 2013
Norris's Avatar
Norris is an unknown quantity at this point
I know this is an older thread, but has anybody used Type R parts for this swap.
I've picked up stock rear knuckles for the base RSX. I just got a deal on Type R parts (hardware, cables, control arms, etc.) I know I'll have to switch out the flanges. Any other ideas or thoughts?
Old Apr 8, 2013
BlueEM2's Avatar
Whachya lookin at?
Check my build thread. It will detail EVERYTHING you need to know about the type "R" swap on the civic. It definitely has its complications vs. a regular rsx swap:
https://www.civicforums.com/forums/4...5-lug-em2.html
Old Apr 8, 2013
Norris's Avatar
I actually just found the link through a different thread "A little project" Thanks for the post
Old Apr 9, 2013
BlueEM2's Avatar
Whachya lookin at?
Good stuff. Hopefully it helps you out.
Old Oct 29, 2013
Engineer4civic's Avatar
Engineer4civic is an unknown quantity at this point
Sorry to revive this thread, just a quick question.
I have a 2005 EM2, looking at doing a 5 lug conversion.
I got my hands on a complete rear setup out of a 2005 ep3, and the front knuckles as well.
I see that all threads related to this require the RSX front knuckles, but can I use the ep3 setup i just got?
Thanks for any help
Old Oct 29, 2013
BlueEM2's Avatar
Whachya lookin at?
Uhmmm.... Yes you can the reason most people use RSX stuff is because EP3s are a lot more rare. Actually the EP3 conversion is a better fit because the ebrake cables work better and a few other things
Old Oct 29, 2013
As for the fronts, can I use ep3 knuckles?
And I know the ep3 have a different p/n for the front lower control arm, but does it need to be changed, or can I stick with the stock ones?
I know the em2 and ep3 use the same ball joint, so would I have the issue that everybody talks about with the tapered washers?
Old Oct 30, 2013
BlueEM2's Avatar
Whachya lookin at?
I'm almost certain EP3 knuckles are fine. Not sure why the lower control arms would be different part #s.
Old Oct 30, 2013
CGaud's Avatar
Only one way to find out...trial and error. I used DC5 knuckles with my 03 Ex and everything seated just fine.
I will add that it wouldn't hurt to put in new ball joints while you're at it because it'll save you some time and money down the road.
Old Nov 1, 2013
BlueEM2's Avatar
Whachya lookin at?
When I did mine I replaced all the wear items. It only made sense since I was there and you can get those parts for relatively cheap compared to aligning it every time something wears out.
Old Nov 1, 2013
Thanks guys. trial and error it is. Going to get the setup off the car this weekend.
And yes, i am planning on replacing the wear items while it is all apart - only makes the most sense i agree.
we'll see how it goes.
now have to find some e-brake cables, the ones on the donor are cut
Old May 7, 2014
JDMxES1's Avatar
JDMxES1 is an unknown quantity at this point
My buddies car is a parts car he has a dc5 and was just wondering can't you just do the knuckle swaps instead of doing that brake swap to. What I'm saying is can't you just use all of the knuckles (all 4) from the dc5 and not do the brake part of it?
Old May 7, 2014
BlueEM2's Avatar
Whachya lookin at?
You will run into problems with this.
I'm not sure if the DC5 ever came with rear drums. (don't think it did tho)
If it did not then the hub on the DC5 will not be compatible with the civic drums.
However. The fronts would be swappable. You would need to find Base RSX knuckles and your OEM calipers would work. You would just need to buy 5 lug discs.
Old May 7, 2014
JDMxES1's Avatar
Sweet, just to clarify this is without the main calipers
Old May 8, 2014
BlueEM2's Avatar
Whachya lookin at?
I used my civic calipers for a while when I did my 5 lug conversion. Then when I got type "S" calipers I Just bought new rotors and everything fit together exactly the same. After youve got the 5 lug swap its just a matter of buying calipers + rotors and your set. Oh pads too of course.
Old May 13, 2014
JDMxES1's Avatar
Thank You, I pulled the front knuckles off couple days ago. Im now looking for a Ep3 parts car that has drums in rears so I can get those too. hopefully its not going too cost me an arm and leg. I spent 0$ on the front two.
Old May 14, 2014
BlueEM2's Avatar
Whachya lookin at?
Converting to rear disc and going to EP3 rear drum setup is pretty much the exact same job. The only difference is E brake cables and brake lines. If I were you I'd bite the bullet and upgrade to rear disc. Also the parts should be much easier to find. After the job is complete make sure you get a proper 4 wheel alignment done.
EDIT: Also. I'm not 100% sure but I thought the EP3 with the rear drums was a 4 lug setup. Might wanna research this.
Old Oct 22, 2018
A-Felix's Avatar
A-Felix is an unknown quantity at this point
Total noob guy here and I have a few questions regarding this swap.
I want to do the 5 lug conversion on my 2004 Honda Civic EX and a K20a2 swap on my car.
1. Should I swap the engine first before the lug conversion?
2. If I do the engine first then according to this guide I will need the items below correct?
Old Oct 22, 2018
BrotatoChip's Avatar
Super Moderator
If you do a K swap you will have to use K series axles, you will have two options.
-Axles from an '02-'05 EP3 or base model RSX can be used if keeping your current four lug setup and also if you're using five lug knuckles from an '04-'05 EP3 only. This would allow you to do the K swap first then worry about the five lug swap later on.
-Axles from an RSX Type S, must then use five lug knuckles from an RSX Type S as well.
Old Oct 23, 2018
A-Felix's Avatar
-Axles from an '02-'05 EP3 can be used if keeping your current four lug setup and also if you're using five lug knuckles from an '04-'05 EP3 only. This would allow you to do the K swap first then worry about the five lug swap later on.
-Axles from an RSX, must then use five lug knuckles from an RSX as well.
Got is so no matter what if I did the swap I'm gonna have to change the knuckle regardless. Can't keep stock.
