Cracked block early R18 Overheating Post Information, Questions and issues with the cracking block on the early R18 type engine here.
Engine replacement help (not much car knowledge)
Old Jan 25, 2021
MeaganM's Avatar
MeaganM is an unknown quantity at this point
Hi everyone! I have a very limited knowledge of cars so I will explain the best I can. I bought a used 07 civic with 85k mikes on it and found out that the block is cracked and after weighting my options I feel like my best bet is to just buy and engine and have a shop put it in. Now several mechanics I've spoken to have said that this year of civic is notorious for engine block cracks. So my concern is that if I get another 07 civic engine from a junkyard or online I might get one from the same batch of engines that have the cracking problems. I have seen several engine on ebay that say "engine for 06-11 civic". Do all these years have the same engine and will it just drop straight in when being replaced? Also, I have the lx model and that doesnt come with a vtec so does that mean a vtec would not fit in my lx? Thanks for any help you guys can offer!
Old Jan 25, 2021
Re: Engine replacement help (not much car knowledge)
Moved to cracked block section.
09 seen to be last year that someone have reported cracked block, so 10-11 so far seen clean.
VTEC will require the ECU, which is also linked to the key, so it will require a lot more work. Recommend using a non-VTEC engine
Old Jan 25, 2021
MeaganM's Avatar
Ok great and do you know if I did get a 2010 engine if it would just drop right in or if the shop would need to do a bunch of work to get the attachment points to align?
Old Jan 25, 2021
They are the same car generation, so should not be that much different
Newby
Sep 13, 2011 01:04 AM
zeshan212
Oct 11, 2010 01:29 AM
DRUMMERGUY791
Apr 28, 2010 06:53 PM
Wardie304
21
Mar 28, 2009 08:45 AM
THEANTIRICEST
Apr 17, 2002 10:41 PM
