R18 Engine
R18 Engine
I experienced the cracked engine block the other day
Civic died out in bumper to bumper traffic no advanced sign of overheating
temp gauge just went straight up.
I was towed to local garage and was told by the machanic to have car towed to Honda
i understand this is a problem with R18 engine with the Cracked Engine BlockSo far honda said they will replace engine .\I will know more whenI get my car back in about a week or two
Does anybody know Why this is not a recall insted of giving an extended warranty.
At least I would be perpared for a problem insted of being surprised and stranded
Live for the Twisties
Re: R18 Engine
Car makers don't usually issue recalls on anything as major as an engine block, it simply costs to much and would be devastating to the stock values. Insteasd they quietly fix them under warranty and as inexpensively as possible. D17 automatic transmissions were also repaired under warranty when they should have been recalled.
Re: R18 Engine
doesnt happen to EVERY r18 but it is pretty common. honda would rather handle it on a case by case basis once the engine blows. rather than replacing millions of engines at once. i think honda would be out of business if they did that. even tho its their own fault for a defective engine design.
jdawgzcivic
May 20, 2015 08:14 PM
