Window stopped working
Old Nov 17, 2022
Pnutt559's Avatar
Pnutt559 is an unknown quantity at this point
I own a 07 civic si, coming home from work today I put my driver side window down, now it won't go up, any ideas? Or how can I make a quick fix so my car won't stay out with it down?
Old Nov 18, 2022
BrotatoChip's Avatar
Super Moderator
Re: Window stopped working
Check the fuse, check the window switch in the door, check the window motor.
Old Nov 18, 2022
123Krash's Avatar
123Krash is an unknown quantity at this point
Mine stick all the time. 08 ex cpe, either will not open or will not close... have to try, and try. slam door, hit inside door panle and maybe it will open and maybe not.
I cleaned and slilconed the tracks as well as I could witout removing the door pane. and that helped. Now every time I get in the car I openand close the windows a couple times.
Sucks whe I pull up to the parking lot gate and have to open the door to reach that keypad with the window closed, or use the drive-up ATM.
It's a toss up and not easy to trouble shoot without a spare switch control unit ot window regulator motors, and expensive to just go buy them and shotgun it.
johnh114532
Electrical
Sep 3, 2022 07:22 AM
iceberg9
Exterior
Jul 21, 2022 09:40 PM
Sourav Das
Electrical
Aug 28, 2019 12:49 AM
Biggie Deaf
Exterior
Oct 2, 2006 07:15 PM
