Interior Post information/questions/Issues about Interiror Parts here.
Rear seat latch stuck
Old Feb 22, 2019
mikedu's Avatar
mikedu is an unknown quantity at this point
Hi team, i have a 2014 Honda Civic hatch with the split fold down magic seats in the rear - the right hand side seat release handle mechanism appears to be broken, maybe the cable has become loose, and wont release the latch allowing the seat to fold down. I cant see anywhere that is possible to access the latch without cutting into the seat to release it. Hoping there is an easy solution...Mike
Old Apr 6, 2019
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
Re: Rear seat latch stuck
There is an access point at the top back side of the seat, the latch mechanism is a U shaped piece that moves left and right to latch unlatch the seat, you may be able to stick a small blades screw driver in this opening to move the latch part. Use a bright light you may need to climb into the trunk or access it from the back seat side that will fold down. Check the cable and level it attached to that moves this U shaped piece, to see if something is broke or lose.
Old Aug 23, 2019
EJayawardana's Avatar
EJayawardana is an unknown quantity at this point
Hi
Did you manage to get this sorted? I've got the same problem now.
Thanks
Emma
Old Nov 28, 2019
Arg0n's Avatar
Arg0n is an unknown quantity at this point
Same problem here. Anyone figured out how to fix this?
Old Nov 29, 2019
Chris Columbus's Avatar
Chris Columbus is an unknown quantity at this point
Same here
Can't see any access point at top of rear of seat like someone said
Old May 26, 2020
Tracey Allpress's Avatar
Tracey Allpress is an unknown quantity at this point
Anyone got any solutions on the above. Our car is the same
Old Jan 20, 2021
Jaga's Avatar
Jaga is an unknown quantity at this point
Hi Mike and all on this group.
Did you manage top get this problem sorted.?
I'm having the same problem with the bigger seat at the back stuck and will not fold.
Getting access to see where the rod has jumped off the lock is my problem.
I think the rod operating the lock via lever on top of the seat (Red/Black) plastic toggle is not releasing the lock via spring./rod.
Any ideas or solutions please?
Any diagram of this mechanism will be most appreciated..
Old Jan 27, 2023
Beedo's Avatar
Beedo is an unknown quantity at this point
Hi all,
This has just happened to me and I will be selling my Civic Estate so need to get this sorted. There’s absolutely no room to even see down the mechanism, the lever has come out so no idea how to access the latch. I went into the local Honda dealership and they want to charge me £160 just to investigate. Any pictures would be welcome.
I also can’t find the access point mentioned by Mild Mods.
Help!!!
Old Feb 9, 2023
Hadi's Avatar
Hadi is an unknown quantity at this point
Originally Posted by Beedo
Hi all,
Help!!!
https://www.civinfo.com/threads/how-...t-fold.419186/
EWLenard
Interior
Dec 13, 2014 03:14 PM
Lopes101
Sep 6, 2011 08:01 PM
swim1979
Apr 26, 2009 09:59 AM
Fern
Jan 16, 2003 12:45 PM
cdmx
Nov 20, 2002 05:00 PM
