Electronics Post information/questions/Issues about Electronic parts here.
AUX port stopped working suddenly [solved]
Old Mar 20, 2011
helpmefixit2007's Avatar
helpmefixit2007 is an unknown quantity at this point
Hello,
I have a 2007 Civic with an AUX input port. today I was listening to my ipod using the AUX port (as I do just about everyday) when all of the sudden it cut out and the display on the car radio switched to the tuner. I could not get the mode to change back into AUX mode when though the ipod was plugged in and was playing. There was no real warning before the music cut out. I was just driving along and then it was gone.
I have checked the Ipod on its own, and the audio cable I was using on its own and both are in working order. The cd player still works just fine, as does the normal radio. The only thing that seems to not work is the AUX mode.
What could be the issue? and is this something that I can fix on my own? (while not an electrical engineer.. I do have a mechanical engineering degree and can follow instructions). Is this something I shouldl take it to the dealer for (I am pretty sure I am out of warranty)?
Any help or advice would be appreciated. I am really going to miss listening to books in my ipod during my work commute!
Thank you!
Old Mar 21, 2011
CraigW's Avatar
re: AUX port stopped working suddenly [solved]
There is a switch built into the aux jack to sense when a plug is present, since you cannot select aux from the panel it sounds like it is not seeing the plug is inserted. You could try reseating the connector on the aux jack (assuming it even has one) or the aux jack may be defective.
If tou look at the 8th gens parts info the part # for that jack is not shown... I have looked in the past. If you find the part # or the problem post it up please.
Old May 20, 2015
barryaz1's Avatar
barryaz1 is an unknown quantity at this point
Did anyone ever resolve this issue? My AUX jack won't recognize the plug. If I push on the plug, I see AUX displayed for a moment, so it seems that the jack/switch is not working. What's involved in replacing?
Old May 21, 2015
CraigW's Avatar
Factory manual is remove audio/hvac portion.
Release clips on AUX jack back side, and push out towards cabin
Old Aug 19, 2015
dcelaya's Avatar
dcelaya is an unknown quantity at this point
Here is how I fixed mine. $25 bucks, and two min of work.
https://youtu.be/OkiT9HSWqIY
Apparently, they just die after a while? I don't know. I have a Bluetooth plugged in for the past year or so. So it wasn't damaged from repeated cable insertions. Who knows, lol. Works now!
Old Aug 19, 2015
CraigW's Avatar
Good fix, could be broken solder joints on the PCB that could be touched up, maybe.
Old Aug 19, 2015
It's a common problem. I tried fixing my gf's 2008 ex aux jack when it crapped itself; took it apart, resoldered connections amd checked continuity with a multimeter, ensured proper contacts with a spare aux cord and the pins on the back of the aux jack itself. Still didn't work properly. Buy a new one and call it a day.
Old Oct 19, 2021
mikett's Avatar
mikett is an unknown quantity at this point
In the Aux port of these cars, there is a small switch to check if anything is plugged in. No idea why they felt this was necessary. Not sure if it's a spring or contact or dust issue but eventually it seems to stop working. I was able to get around it for a while by hanging something heavy like my pocket knife on the aux cord. (That's good for them, right? Extra strain?)
My fix was pull it out, check continuity between the pins and the ⅛" headphone plug and using some thin wire, jump out the other 2 pins that were that switch. (Pictured) Seems to be working great.
2 right pins shorted out.
Works so well that I no longer need that pesky cord plugged in.
Old Sep 9, 2023
ye566466w5y7we7's Avatar
ye566466w5y7we7 is an unknown quantity at this point
Re: AUX port stopped working suddenly [solved]
made an account just to say thanks. Just soldered those two pins like you did and it fixed the problem
sean_incali
Suspension
Feb 23, 2019 03:19 PM
Uareabozo
Jul 19, 2012 11:12 PM
chzm
Mar 6, 2011 10:11 PM
Krumenager
Oct 23, 2008 08:11 AM
