gas milage and muffler....
Old Jun 14, 2003
shawnskee22's Avatar
local 7thgen rugger!
shawnskee22 is an unknown quantity at this point
the gas mileage in my 2001 civic has been really low lately, or at least comparatively so. i recently put a tsuedo double tip muffler on it and im wondering if that could have done it. i only had the car for like a week or two before i put on the muffler so im not really sure if that is the problem or if it is something else, because the tank before i put on the muffler was pretty low too. when i put on the tsuedo we cut off the very last muffler and ran straight pipe from the first (maybe second) muffler all the way back to the new tsuedo. could this be why my mileage has been bad?
Old Jun 14, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Re: gas milage and muffler....
How many miles per tank did you achieve before? after?
Old Jun 14, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
it could be that you are running your car hard which in turn is sucking alot of gas since you added an exhaust.
Injen
Old Jun 14, 2003
one of the tanks that i drove on before i got around 420 miles on it so it would be around 32 mpg then the next tank before the muffler was around like 24/25 and its stayed around that since then.
Old Jun 14, 2003
injencivic's Avatar
i would reset your ecu and see if that helps any. it sounds like you are just running it hard and might not have reset everything. but your car should reset itselfs in an undetermined amount of time that i am not sure of.
Injen
Old Jun 15, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
cat back exhausts don't affect mileage right?
Old Jun 15, 2003
how do i reset my ecu?
Old Jun 15, 2003
ak's Avatar
ak
Retired Mod
search...
sf3r8z
Apr 19, 2016 01:53 PM
mistahlorax13
21
Nov 18, 2015 12:47 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
