Power Steering?
Old May 31, 2003
VTECTypeR's Avatar
Power Steering?
Lately when I steer when im not moving or going real slow, it seems as if my power steering isnt working well. It makes this sound when i move the steering wheel. I checked the power steering fluid and it was full so i have no clue what the problem is.
Old May 31, 2003
VTECTypeR's Avatar
No one knows?
Old Jun 1, 2003
Weaponx12o's Avatar
be more specific.. does the wheel feel heavier (harder to turn)? describe the sound it makes. is your car lowered or have any suspension mods?
Old Jun 1, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
You mean the hissing sound? That sound is normal.
but yea, is it heavier? not smooth?
Old Jun 1, 2003
VTECTypeR's Avatar
Its not as smooth and easy to turn.
Old Jun 2, 2003
bluelight's Avatar
bluelight is an unknown quantity at this point
oh yea, same here...it feels heavier.
Old Jun 2, 2003
wcsjunior's Avatar
Supreme Member!
if it makes a whining noise then ur power steering pump might be busted becuz u theres still fluid in there. the best thing to do is take it to a shop and have them check the pump. the way u can find out for sure is pop ur hood and look at the pump, tell someone else to turn the wheel while ur hand is on the pump(if its too hot then use a stick or something) by doing that u can feel it vibrating and making the whining sound. if it does that then u will probably have to buy a new pump.
Old Jun 2, 2003
VTECTypeR's Avatar
Ill be takin in it to honda soon so il let them see whats wrong
Old Jun 2, 2003
flotsamm's Avatar
You check the belt tension? Maybe you have a loose belt.. just guessing.
NoobyKid
Jul 13, 2015 07:53 AM
hans.pcguy
Jul 12, 2015 12:19 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
hayden55
Jul 8, 2015 11:38 PM
cgavin1
Jul 7, 2015 07:10 AM
