HELP!! My Rear Night Light Doesn't Work
Old May 25, 2003
vkylau's Avatar
vkylau is an unknown quantity at this point
Mine is a Honda Civic 2002 Sedan
I have touched the on the Light Bulbs yesterday. Today, I notice that one of the left hand side brake light (STANLEY#168) burned. That fine, I will just buy a new one and replace it. But I Also noticed that both of my civic's Night Beam Light (7443STANLEY#24B) all doesn't work on the rear. Front is fine. And the Guage Light (which display the speed, fuel....) doesn't work also.
what would the major problem caused by this? okay, even if you say i touched the rear light yesterday and made it burned, but how about the guage night light? i never touched that.
so.. now when i turn on the night light suppose the front, rear, and the guage will light up, but now only front light up, thats it. HELP!! thanks!
Old May 25, 2003
CarbonFly's Avatar
MOVED to the CORRECT forum!!!
Old May 25, 2003
vkylau's Avatar
HELP PLEASE~
Old May 25, 2003
ZMan2k2's Avatar
The Man, Myth and Legend
From: Western Canada, where the beer is cold and the women are HOT!
ZMan2k2 is an unknown quantity at this point
Best answer I can give you is a fuse or a wiring short. If you removed your guage cluster at all, that may be an area that you want to consider. Either pull the cluster and look for a burned or cut wire, or take it to the dealership and have them run the wiring.
Old May 25, 2003
vkylau's Avatar
if fuse, which fuse should i change? fuse#1 to #25, which one? thanks!
Old May 25, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Look at the plastic fuse covers.....there's the fuse map.
Old May 25, 2003
civicvtec1ps's Avatar
Search and Learn
check fuse box under the hood and look at the black plastic fuse cover.
they do have map that you can check. it should be fuse problem.
you can also buy fuse tester at autozone or any autostore for less thatn 10 bucks and you could use that..
Old May 25, 2003
Voiceofid's Avatar
End Bringer
this happened to me a couple times, i lost taillights, headlights and all my interior lights
it's a fuse, "small light" or something like that on the box cover of the fuse box in the engine bay.
Old May 25, 2003
vkylau's Avatar
i did, but i don't know which one is it.
FUSE#01 = IG COIL
FUSE#02 = LAF HEATER
FUSE#03 = DAY LIGHT
FUSE#04 = ALTERNATOR
FUSE#05 = /
FUSE#06 = P/W RELAY
FUSE#07 = SUNROOF
FUSE#08 = ACC RADIO
FUSE#09 = RP WIPER
FUSE#10 = METER
FUSE#12 = ABS
FUSE#13 = DAY LIGHT
FUSE#14 = SRS
FUSE#15 = /
FUSE#16 = HEATED SEAT
FUSE#17 = FUEL PUMP
FUSE#18 = ACC CIGAR
FUSE#19 = TURN LIGHT
FUSE#20 = FP WIPER
FUSE#21 = /
FUSE#22 = AS P/W
FUSE#23 = DR P/W
FUSE#24 = RP L P/W
FUSE#25 = RR R P/W
Old May 25, 2003
ak's Avatar
ak
Retired Mod
How about under your steering wheel? There's a plastic panel that you can remove....and there's another fuse box there.
More light fuses there... post
Old May 25, 2003
vkylau's Avatar
i opened that cover, on the cover, there have a fuse map. as what i posted above fuse#1-25
are those fuse suppose can light up? i mean the fuse itself. or which fuse should be caused by the guage-light and the rear night light? thanks!
Old May 26, 2003
vkylau's Avatar
HELP PLEASE~
Old May 26, 2003
Voiceofid's Avatar
End Bringer
if you can't be sure, just try pulling every single one of them, one by one, you would've had some sucess already
check 3 and 13
they don't lite up, all you have to do is take it out with the fuse pulling tool, and look at it under a light, there should be a little snake shape piece of mettal that connects the 2 ends of the fuse. check the middle and see is there a disconnection on the fuse it self
Old May 26, 2003
vkylau's Avatar
turn off the car and pull out the fuse?
then have to turn on and off the car many times?
or i can just pull out the fuse with the car in on? thnaks!
Old May 26, 2003
Search and Learn
turn off the car. check the fuses.. you can do that just by looking at it. there some extra replacement fuses under the hood as well. you could use that or go to auto parts store and go buy auto fuses for less than 5 dollars. once you figure out which fuses are blown. just replace it . throw away blown fuse/fuses then turn on car. you be ready to go by then..
slynger
18
May 8, 2015 06:06 PM
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
darwin-t
Apr 18, 2015 09:29 PM
