HARD TIME STARTED UP THE CAR
Old May 15, 2003
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
Today in morning i got hard time starting up my car it did start but it take aleast 5-6 second to started. It done a few time it sometime but not always. i don't know what wrong with my car but this is brand new 03 civic with 1,400 miles on it. it shouldn't do that because is new car. Do that ever happen to you guys? should i take it to dealership? I got 2003 civic ex coupe manual with only 1,400 miles on it .
Old May 15, 2003
Take it back, although there is not much they can do. My starts seem to improve when I add fuel-injector cleaner to the gas.
Here is a trick. Turn the car to the ON position and wait a few seconds before starting it. This gives the fuel pump time to charge.
Old May 15, 2003
flotsamm's Avatar
Sometimes taking the key out then re-inserting it can help also.. I think it has something to do with the Immoblizer system.
Old May 15, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
might have a bad battery
Old May 15, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
There isn't much they can do unless they can replicate the problem while they have it. Mine does it on occasion, usually when theres less than 1/3 tank of gas and its humid. I just ignore it cuz it doesn't happen too much, but unless the dealer can get the car to foul up, they can't fix what they can't find.
Old May 15, 2003
QTPie's Avatar
QTPie is an unknown quantity at this point
Hey my 2002 does this no start problem ... so we raised some hell at the dealership and they actually looked into it ... but all they came up with is the demmobilizer system malfunctioning ... it is actually caused by the key not being properly read by the ignition ... if you look at your dash lights when you first put the key in the ignition, before you crank it, watch for a green key light. wait for this light to go out before you start the car. During this time the system is attempting to recognize the key, and the car will not start until this occurs. If it doesn't happen after about 2 seconds, take the key out, flip it over, and reinsert it. They say this problem is usually caused by interference from either other keys on the same ring as your civic key, or from the door lock button, and they are supposedly working on the problem to recall it as soon as they can.
If anyone hears anything more about this problem it would be great to know!
Old May 17, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Yup, what QT pie said
Old May 29, 2003
Gecko's Avatar
Having same problem with my 2002 lx. Try out some of the advice posted here
Old May 29, 2003
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
QT, said it. I went to my dealer for an oil change and asked about it. The service advisor said the same thing. Honda is alos have problems with the system on the newer CRV's
CarStuff
Dec 6, 2020 12:52 PM
dragonsblood
Apr 27, 2015 12:28 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
