problem with trunk
Old May 9, 2003
quicksilver's Avatar
quicksilver is an unknown quantity at this point
problem with trunk
okay well like it says as the topic i have a prob with my trunk! about 3 weeks ago i locked my trunk from the inside so that no one could break in to it.anyway i went to unlock and pop my trunk but it wont work . i unlocked,locked, and unlocked and it wont open. my car isnt under warranty so what do i do!i can only open my trunk from the outside!
Old May 10, 2003
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
i am having the same problem! dunno if this will work for you, but after you insert the key, push it down and to the right as you try to turn it to lock/unlock. if it clicks, you know it works. good luck!
Old May 13, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
hey i had the same problem and so have a lot of people, for some reason the locking cylinder is coming disconnected, if you just pop off the cover next to the key hole you can see what im talking about, just connect it back up and dont lock it unless you want to spring for a new cylinder.......
Youshoe
May 22, 2015 09:36 PM
carhag2000
Apr 25, 2015 01:33 PM
cperez53
Apr 16, 2015 09:31 PM
0100010
Dec 1, 2001 03:27 PM
