Keyless entry + central lock
Old May 9, 2003
cheebicFerio's Avatar
cheebicFerio is an unknown quantity at this point
Good day folks, I am in desperate need of some advise. After installing my sound system, my keyless entry is unable to work. even using the key to unlock, the central lock is not working. Check the fuses only found the door fuse blow, I've replace it and still the central lock does not work. I've check thru the wirings coz I've place accumat in the doors, but the wiring seem good. Also, on a very random basis, when i press the keyless entry, I can unlock all 4 door, but only once and unable to get it to work again. this problem persist for almost a week, wiriing and fuses has been check by 3 shops found to be good. I cannot go back to honda coz the car has undergo relative amount of changes. Know anyplace to see the technical manual use by Honda to fix the car ?
Old May 9, 2003
solar's Avatar
solar is an unknown quantity at this point
Do both keyring transmitters do this, because its possible the battery in your transmitter needs replacing.
Old May 9, 2003
ya, both. the sad part is, I manually uses the key to unlock, only the key door unlock, the rest of the 3 remain lock.
Old Jun 3, 2003
CIV-IIC's Avatar
CIV-IIC is an unknown quantity at this point
hey i remember reading about this somewhere and from what i can remeember the central locking has something to do with your original deck. if you take out your original deck then ur central locking wont work. i remember reading it on a forum somewhere, but id say thats ur problem. not sure how to fix it though. sorry mate
Old Jun 4, 2003
Went to my local dealer, met a good man that did a diagnostic. The cause of the remote lost is indeed due to the cutting of the stock radio which result in messing up the computer settings. However, the honda guy told me our car may be able to re learn the settings after a reset. The lost of the central lock is due to the installation of the speaker, my installer accidentally drill the wire of the actuator causing a short to chassis. So problem boils down to the audio shop that did my car, anyway, already claim back the money I spend to rectify the problem.
Thanx for the post.
h4ldol
Apr 24, 2017 08:16 PM
fvckbg
Oct 20, 2016 07:37 PM
sesi
Oct 1, 2015 02:03 PM
frank_kleng
Sep 29, 2015 10:55 PM
Bruce2
Sep 27, 2015 08:45 PM
