Warrenty Question
Old Apr 27, 2003
DaZeD's Avatar
Don't Hate. Just Envy.
Warrenty Question
So, I'm thinking of lowering my car 2 or 2.5 inches and I was wondering what that will do to my warrenty, i know a lot of you have already done this
Old Apr 27, 2003
R3DL1N3's Avatar
if you get a problem with your struts your warranty wont cover it because you lowered it. i know that for sure.
Old Apr 28, 2003
askibum02's Avatar
askibum02 is an unknown quantity at this point
In fact, the only part of your warranty that will be affected is the suspension.
Old Apr 28, 2003
mattskav's Avatar
mattskav is an unknown quantity at this point
The burden of proof is on them, there is a federal law that states that they (not you) must prove that any modification to the vehicle directly contributed to the failure of a component in order to void that portion of your waranty.
So in the case anything affected by droping the car would not be covered, i.e. the struts, ball joints, axles, wheel busings / bearings tie rods etc.. that see forces not accounted for in the initial design.
If anything does go wrong that costs lots to fix, you can always take the stuff off before bringing it in, thats what most people do...
Old Apr 29, 2003
Connie's Avatar
I would personally get your struts checked before lowering because it has proven to be quite a problem on '01 and '02 civics, I dont know about '03's though.
Old Apr 29, 2003
askibum02's Avatar
If you are lowing your car, you should always get struts that are meant for lowering. Factory struts aren't made for it and will blow in short order.
Old Apr 29, 2003
Huh_Oh Sh*t!'s Avatar
Huh_Oh Sh*t! is an unknown quantity at this point
just put back the stock springs if ur struts go bad n take it into the dealer. as long as u have everything stock itll be covered by warranty.
Old Apr 29, 2003
flotsamm's Avatar
Call your dealer and ask them. My dealer will cover a lowered Honda as long as they performed the install. Give them a call, yours might also..
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
