rattling noise
Old Apr 20, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
rattling noise
so i'm getting this rattling noise on my side air vents and doors. it's a "tap tap tap tap" and it only happens over rough roads/freeways. i took it to honda and they said they won't cover it on warrenty cause i lowered my car?.... weird so i'm just seeing if anyone here had this problem and if so how they solved it.
thanks!
Old Apr 20, 2003
dragoon's Avatar
fatmat
Old Apr 21, 2003
Wanger's Avatar
Originally posted by dragoon
fatmat
http://www.7thgencivic.com/forums/sh...ghlight=fatmat
this thread says fatmat does not help rattles in any shape or form.
Old Apr 24, 2003
Mine makes that noise, but I think it's the shocks if it's coming from outside
Old Apr 25, 2003
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
it is most likely the struts and no, the dealer won't cover it under warranty if you have lowered your car. are the struts factory? if so, make sure the 3 bolts on top of the stut tower are tight...very tight. If you have access to an air gun, use it.
Old Apr 26, 2003
AR's Avatar
AR
e-married to daydreamer
is it in the interior or on the outside? thats probably cause its from your suspension. . . if its coming from outside, plus they siad they wont cover it cause youre cars dropped.
Old Apr 26, 2003
Wanger's Avatar
it's in the inside trim.
Old Apr 26, 2003
CivicBR900EX's Avatar
Master
CivicBR900EX is an unknown quantity at this point
trim i think
junkyardguy
20
Sep 6, 2015 10:07 PM
cja3455
Aug 24, 2015 06:20 AM
Yazan93
Jul 14, 2015 08:56 PM
fvckbg
Jul 7, 2015 07:08 PM
