Ignition Problem
Old Apr 11, 2003
THEANTIRICEST's Avatar
Premium Member & 1 Millionth Poster!
THEANTIRICEST has disabled reputation
Ignition Problem
Every so often about 1 out of 15 starts of my car I have to really hold in the key for a while for it to start. Is this the sign of an impending serious problem?
Old Apr 11, 2003
Vytas's Avatar
Vytas is an unknown quantity at this point
Same here, besides, I have some other funnie noises...But , no major problems yet
Old Apr 11, 2003
Ike's Avatar
Ike
Ike is an unknown quantity at this point
I sometimes have the same problem, just not as often.
Old Apr 11, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
is this only a COLD weather start? What is your mileage? It could be just a bad ECU code that needs to be adjusted by the dealer. I once cranked 7 times before the enigine started. It was due to a bad ECU code. Now it's fine HOT or COLD. 3-4 cranks to start.
Old Apr 11, 2003
flotsamm's Avatar
It happens to me also, but all I do is remove the key, re-insert it and it starts right up. Doesnt happen very often though.
Old Apr 11, 2003
2k1sscivic's Avatar
2k1sscivic is an unknown quantity at this point
I've inserted the key and switched it over to start it and nothing, I try it again and it starts. Rarely happens
Old Apr 11, 2003
Mbow's Avatar
Happend to me 1 time when the wife was picking me drunk **** up. Wouldn't start and I managed to tell her to remove the key and reinsert it. She did and off we went.
Has never happend since...about 6 months ago
Old Apr 11, 2003
CuRiOuSfIsH's Avatar
Back From The Banned!
Try turning the key slower... turn in to the 1st click, then slowly turn the key till ignition, that sometimes helps.
Old Apr 11, 2003
Mbow's Avatar
Yes, turning the key to just before the engine starts makes the fuel pump operate and pressurize the system.
I think most everyone is referring to when the car won't start, period.
roverben
Jan 21, 2019 05:16 PM
mrohitredd
May 28, 2015 10:03 AM
pincookie1
May 4, 2015 12:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Doc
Dec 12, 2001 11:47 AM
