creaky sunroof
Old Mar 7, 2003
rscivic's Avatar
rscivic is an unknown quantity at this point
creaky sunroof
Does anyone have an annoying creaking (sp?) sound that the sroof makes when the door is slid shut? I asked the dealer and they claim it needs to be lubricated- b s*#%....[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 7, 2003
Weaponx12o's Avatar
maybe it does need to be lubricated, i've never had that problem happen to me
Old Mar 7, 2003
branden's Avatar
branden is an unknown quantity at this point
you can lubricate it yourself. try getting some silicone based lubricant on the rubber beneath the sunroof glass. or any grease should do just apply a light film to it and the mechanism at the rear if you can reach it.
Old Mar 7, 2003
Mbow's Avatar
If it is only heard when you are moving the shutter back and forth, it would make sense that the track needs to be lubed. Also, if that is the only noise you are getting from the sunroof and general area, count your blessings.
Old Mar 7, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
Mine only creek whens the lid isnt s**t! Go figure. The creaks go away if i slide it back over and cover it.
Old Mar 8, 2003
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Mine started sqeaking once when I hadn't lubricated the seal for awhile. To test if it's the seal, push up on the glass while you're sitting in the car a couple of times, and it should make the noise. Just slap some sort of rubber conditioner (Meguiar's vinyl/rubber dressing seems to work well) on the seal, and you'll be good to go.
Now, my headliner also rattles like a bitch around the roof opening, but the dealer seems to be deaf.
h4ldol
Apr 24, 2017 08:16 PM
SammySC
121
Apr 7, 2017 07:43 PM
speedlever
Sep 24, 2015 07:18 PM
EM2661
Sep 11, 2015 06:01 PM
First Car
Sep 8, 2015 08:54 PM
